Intel Motherboard Logo
A
Anonymous Posted on Jul 14, 2014
Scan for audio drivers - Intel Motherboard
Lars Olsson
Level 3:
Brigadier General:
  • Intel Master 3,400 Answers
  • Posted on Jul 14, 2014
Lars Olsson
Intel Master
Level 3:
Brigadier General:
Answers
3400
Questions
Helped
1048556
Points
10330
No sound drivers on HP Pavilion dv7-6135dx
DOWNLOAD YOUR 'AUDIO DRIVER' FROM HERE...FIND IT IN THE DOWNLOAD FOLDER, CLICK IT...
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4062&lc=en&cc=us&dlc=en&sw_lang=&product=5118761#N189 ...DOWNLOAD YOUR AUDIO DRIVER, FIND AND OPEN YOUR DOWNLOAD FOLDER, CLICK ON 'AUDIO SETUP' AND IT WILL INSTALL...REBOOT AND YOUR COMPUTER WILL LOOK FOR IT...IF NOT DO THE FOLLOWING...
RIGHT CLICK ON MY COMPUTER...CLICK ON MANAGE, LEFT CLICK ON DEVICE MANAGER, RIGHT CLICK ON 'SOUND..(VIDEO...GAME) , LEFT CLICK ON SCAN FOR HARDWARE CHANGES...COMPUTER WILL SCAN AND INSTALL YOUR AUDIO DRIVER...AFTER IT FINISHES ...REBOOT YOUR COMPUTER...COMPUTER WILL EITHER HAVE SOUND RESTORED OR WILL LOOK FOR YOUR DRIVER...HOPE THIS HELPS.
1helpful
Sound card,i need a driver on sound card cs428
If you can find the driver in google use this software.
DRIVER ROBOT
http://www.mediafire.com/?hwh6v0yymmrsho8
Download, Extract and install the software.
Once the software is activated, Start the SCAN to scan your computer for driver problems.
After scanning look for your audio device and click download.
This will automatically download you sound driver.
Goodluck. Please Give me updates if you have any success. THANKS.
2helpful
2answers
I dont have sound on computer if i try open music files on windamp i get msg bad sound device in device menager multimedia audio controler have yellow solour ?
This is so because you need to install the correct audio drivers for your sound controller. You need to go to the manufacturers website and download and install the latest Audio Driver for your system. Then your sound will work.
I receive the message "DRIVERS NOT FOUND!REBOOT YOUR SYSTEM"When installing sound softwares on my compaq nc6320
missing or corrupt audio drivers
do a thorough scan you system for viruses if you do not do so regularly
do a surface scan of you hard drive
3 possible solutions (assuming widows os as you do not say)
1 insert you os installation disc - go to control panel \ system \ hardware \ device manager \ sound \ (audio hardwares) - select all audio drivers - right click, update
2 go to http://welcome.hp.com/country/us/en/support.html download audio drivers specific to you model, install per their instructions
3 if you have install one of the many quirky av apps you have to go to their website to download & install their proprietary drivers
Audio driver is not getting installed so i want to download audio driver for windows xp2
Which audio-device?
Is it an "add-in" PCI audio-card? Manufacturer? Model number?
Or, is it some "integrated" circuits embedded in the motherboard?
Either way, without such details, it's impossible to answer your question.
You could try: http://WindowsUpdate.microsoft.com
Click "Custom" scan.
When the scan completes, click on "optional hardware updates", to see if Windows Update can deliver a device-driver for your audio hardware.
1helpful
2answers
I installed a new window xp pack 2 and now i am not able to installed my audio drivers it's showing me some (audio bus) which is not intalled so wt i do nw form where i get d drivers
well.. just go online and check for the audio driver for your computer.. it will auto scan your Pc and give you suitable driver. otherwise thers are many software available which scans your computer and recommend you remaining driver to install from internet.
Multimedia audio controller missing whenever i try to instal it once i got to the last part my computer suddenly restart..
Are you installing the correct audio driver? Where are you installing it from?
Here's an easy way to get or update your sound drivers:
You could try to use this driver scanning tool, which scans the computer for needed drivers and has an option to automatically retrieve them for you.
You can download this free driver scanning tool from here or directly from this link.
After you have downloaded the above file, double-click on it and follow the simple steps to install it. Then, when it asks if you want to run it, just answer yes. This is easier than manually searching, downloading and installing the drivers.
If, after trying the above, sound doesn't work, you can try with the System Restore utility. To know more about System Restore, go to this link.
Hope that helps,
Regards,
Raspal
No mixer device on windows xp
I say, you need to install the sound driver for your audio device on windows xp system.
If you have built in audio device, you can scan your system using the Driver Magician software
http://www.drivermagician.com/DriverMagician.exe
scan your system for drivers. and it will give you link for you to download the drivers needed by your system .
No audio
Get your audio driver here:
http://www.driverstock.com/ASUS-M2N-MX-driver-download/6-9-10275/index.html
Steps:
  • Below the Free Scan image, there are audio drivers with corresponding compatible operating system for you. Choose the right one.
  • Click "Download ASUS M2N MX Audio driver" link
  • New page will appear. Below the Free Scan image, there's a generated code. Enter the verification code.
  • When verified, choose external links.
  • You can now start downloading.
*Your vote is highly appreciated. Thanks in advance. I am here to help you.
Scan,remove and fix proper audio and sound driver
HTML clipboard Hi Friends,
Acer Aspire 5610-4648 PC Notebook main problem is Web Cam Problem, Windows XP Problem etc.
For these problem you can visit a link by just Click Here .
For any other problem with this Notebook you can Click Here
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
