Question about Husqvarna YTH21K46 (46") 21HP Lawn Tractor 960 43 0085
Parts manual for a yth21k46
Ineed the part # for the motion belt
    New Friend:
  • 21 Answers
Type: Husqvarna YTH21K46 into google where you will find the manual in .pdf and a complete parts list.
Posted on Jan 05, 2015
SOURCE:
Blades will not engage
when you actuate the "engage blade" lever, two things may occur,
First, a mechanical action, a spring moves to put tension onto the belt.
Second; at the end of its run, actuate a switch (PTF switch) to engage the clutch that moves the pulleys that consequentially move the blades.
if the tensioner is not moving , check if spring has come lose, undone or broken, (more likely in your case) or check the PTF switch.
any other assistance, contact me, good luck.
If you need further help, reach me via phone at https://www.6ya.com/expert/gerardo_79638d1eac6a0a1f
Apr 20, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Hydraulic system
I would say,that the Motion Drive Belt,has stretched to the point,that it is slipping on the pulleys. Over time all belts stretch or break. There is no adjustment,that can be made,once stretched,its time for a new belt. Look in your Owner's Manual,to see,a picture and directions of how to remove and replace a motion drive belt. If there isn't a picture of the drive belt in your manual,then look under the left foot rest. There you will find a decal,showing the correct method to install the belt over the pulleys. This is going to be a long belt,it runs from the Transaxle to the motor's upper pulley assembly. You can,it will be hard to do,remove and replace the drive belt with the mower deck attached. First,try lowering the mower deck,to the lowest position. This will give some room,to get to the motion belt,you will have to remove the mower belt,to get to the motion belt. I find it is easier to just remove the mower deck entirely. Doing this,give you ample room to work on the motion belt. The mower belt,can be purchased from Sears Parts Direct. Give them the tractor's Model Number and the Belt Part #,if you have the number,they will look it up anyway,if not. I gave more information,than you asked for. I hope this will help you. Sincerely,Brad Locke DTD. 12/04/15
Jul 15, 2013 | Sears Craftsman 46 in Mulching Tractor...
Drive belt slips on Husqvarna YTH21K46 riding lawnmower, installed new drive belt and it slips. mower is 2 years old
I had this same issue. New belts and correct routing did not solve the problem. The issue with my mower was the tabs that come off the frame that you bolt the transaxle (the drive for the rear wheels and axle) had almost completely torn/cracked away. This allowed the transaxle to tilt forward under a load and slip the belt off the rear drive pulley. You see no mention of this at the dealer or company sights. The tabs are so thin this is going to happen, in my opinion, in time. I reinforced this area with 1/4 inch angle iron and have had no further belt issue.
Apr 21, 2012 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Is there a way to tighten the deck belt? i have gone through 2 belts and they dont seem to be tight around the pulleys.
Your deck should have a couple "idler" pulleys on them in addition to the main mandrell pulleys that have tension on them via springs to keep tension on your deck belt. Maybe you need to really examine the condition of those "idler" pulleys and also the main pulleys to find the problem.
Sep 10, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Mower will not go forward or reverse. Starts up and runs fine!!
Drive belt has snapped just go to a dealer with the broken belt to make sure U get the right belt then replace it.....maybe a friend can help you??? Pretty easy....
Jun 13, 2011 | Husqvarna YTH21K46 (46") 21HP Lawn Tractor...
Husqvarna YTH21K46 (46") 21HP Lawn Tractor  960 43 0085 Logo
133 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
Jay Finke
Jay Finke
lnbn1975
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
