SOURCE: Camera turns on for a few seconds, then off.
A light rap with a knuckle when powering up fixed the problem, at least temporarily. Lens extended, camera works fine. Not exactly a technical fix, but it worked for me.
SOURCE: how do I download pictures from Polaroid t1031 to pc?
Turn the camera off and connect the usb cable to the pc. Turn the camera on. Open my computer and you should see the drive listed under removeable drives. Double click on it and drill down until you find your pictures.
Rob
SOURCE: Camera not coming green light just blinking
Try 4x normal AA batteries. (new)
Also ensure that the memory card cover is firmly closed.
SOURCE: file error/polaroid camera polaroid t1031
I have the same camera and that happens to mine sometimes. That happens when something wasn't right when you took the picture. If you press the delete button while it has the "file error" on the screen, it will delete the file and then you can continue use with your camera. Sometimes when this happens it freezes the camera so you have to turn it off and back on, then try deleting it. I hope this helps you!!
