I'm receiving Error 58.04 on th HP laserjet P4014n How do I shut it off?
SOURCE: i have hp laserjet 3050 and i not able to receive fax
Hello Rupesh,
Following is the description for Error 232
A communication failure (comm error) has occurred between the two machines.
OR
The user at the remote machine may have pressed CANCEL.
OR
The power at the remote machine has been interrupted, or deliberately turned off, causing the fax session to be interrupted
Disable V.34 on local machine
V.34 is the modem protocol used by the product to send faxes. It is the worldwide standard for full-duplex modems sending and receiving data across telephone lines at 1,200 or 2,400 bps. The default setting for V.34 is ON.
Follow the steps below to disable V.34 setting.
top
Disable or Enable the ECM
NOTE: The default setting for ECM is ON.
SOURCE: my laserjet p4014n keeps giving me a 51.10 error
it means that the laser beam is not detected.
Try to change the toner.
SOURCE: my hp laserjet P4014n is
Hi! I will be glad to assist you in this issue.
Usually all you have to do is initialize hard disk even if you do not have one.
Just turn off the printer. Turn the printer back on and when the memory starts
to count hold down the menu key until all three lights come on. When all three
lights are on solid release the menu button and press the arrow back button and
initialize disk should appear in the menu. Just hit the check mark button again
and it should take care of the problem.
Here is the link just incase you need more solution:
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bpl12422&jumpid=reg_R1002_USEN#A46
SOURCE: Brand new HP P4014n gets an Error 51.10 when it
That's a laser/scanner error.
Get to the DIAGNOSTICS menu. Run the laser/scanner motor component test.
Listen as the motor rotates.
Call HP. your printer is under warranty. Tell them if you heard the motor noise.
