Dryer shows F1 on my dail
f1 is usually a bad computer board or control board same thing,you could have a loose wire you can check the board for a loose connection but most likely it will be the board itself,f1 is a communication error,when you start the dryer the board sends out signals to all the other parts in the dryer if it can't connect with one of the parts f1 will come up,it's telling you the board isn't connected or the board is damaged and can't communicate with other parts so if the board is damaged or there's a loose connection this will happen,if the board did connect with another part and the part failed it would give you another error code
