Bosch PowerStar AE125 AE125 Whole House Electric Tankless Water Heater... Logo
A
Anonymous Posted on Jul 13, 2014
How to repair bosch powerstream redring model rp12pt
Red light does not come on and no hot water. it has been reset and breaker checked
3 Related Answers
Anonymous
  • 25 Answers
  • Posted on Jan 19, 2009
SOURCE: Bosch 125 Tankless Water Heater - Water not hot enough
Sounds more like the venturi in the watervalve of the tankless water heater is clogged. I would recommed rebuilding it and paying close attention to properly relubing the pushrod and cleaning the venturi.
co7196
Ned C Cook
  • 3433 Answers
  • Posted on May 06, 2009
SOURCE: no hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
Anonymous
  • 3 Answers
  • Posted on Dec 25, 2010
SOURCE: heater is ae125 is about
Hey did you ever get this fixed mine is almost the exact same thing we've been using ours for about 3 years and today nothing. Thanks for your help.
Hear no clicking when I turn on switch inside my unit, suburban water heater model sw12de. Could igniter be out?
Could be your igniter or possibly your control board. The red light not being on indicates you most likely have an electrical issue. Check your breaker as well. If you nee any parts this site will have them all
http://www.suburbanrvparts.com/
Bosh rp12pt schematics
call bosch ----- they have what you need and maybe online for you
I have a PowerStar tankless electric water heater, model #44-557710 and it was replaced about 3 months ago. This morning I had hot water and this afternoon I do not. When I call for hot water a red light...
Call Bosch. And exercise your 10 year parts warranty rights.
Copy following link for Bosch power star manuals:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html#Ariston
Check circuit breakers, fully off and then fully back on. Test if voltage is at least 80% rating plate on unit. Check that temperature dial is set correctly. Call for service again.
Don't install tankless computer that heats water. You cannot fix this computer yourself, and they are problematic for owners.
Go to Lowes right now, spend $285 and buy tank-type electric water heater, roll it into your house, and save money, since the electric tankless computer heater costs average $100 more per year to operate than tank-type heater for average family of 4.
Tank type heater can be repaired by homeowner same day for $25 using off-the-shelf parts from hardware store. And that empowers the regular guy, and gets you off the junk tankless treadmill.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Cannot find pilot light on my bosch GWH635ESL, help!
Call Bosch
Gas Products Technical Support: 800-642-3111
That model number is only shown at one website, and that model number is not shown at Bosch.
Open following link for Bosch:
http://www.boschwaterheater.com/BoschHotWatercomHome/GasProducts/tabid/331/Default.aspx
Search of Bosch for that model number shows no result.
Some water heaters do not have a pilot light. Instead they use hot surface igniter rod that glows red hot
The igniter rod ignites the gas after solenoid valve opens and gas flows to combustion chamber.
The igniter rod and heat sensor have to be operational, and have to be positioned correctly for ignition to take place.
If igniter rod is not working, or if heat sensor does not detect flame, then gas solenoid valve shuts down and water heater does not heat water.
Powerstar 115 tankless tripping reset ontop of #2 heat chamber #1 does not get overly warm mainly because of incoming water temp. but #2 seems to be heating after water flow stops to hot to touch and...
I don't have specific suggestion for tankless tripping breaker or if that is a circuit breaker problem or a tankless problem.
1) Move wires to another same-size breaker and see if problem persists.
2) Compare amp draw on tankless label with wire size and breaker size amp rating.
For example 30 amp breaker using 10ga wire is rated for 80% of listed amps or 24 amps.
3) If you are drawing full 30 amps, then 30 amp breaker is getting hot. Breaker trips with heat. Older breakers can trip more easily.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) Before calling service technician, open following link for Bosch troubleshooting steps.
5) Be sure to read manual for yearly maintenance requirements.
6) Add a tempering tank for incoming cold water problem.
http://waterheatertimer.org/Tempering-tank.html
7) All gas tankless brands can be repaired by homeowner for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
No hot water
Electric water heater can be repaired by homeowner.
Four things can cause NO hot water:
1) ECO red reset button tripped. Remove top cover on water heater, push red reset button on thermostat. Put insulation and cover back over thermostat.
2) Circuit breaker is tripped, circuit breaker bad, or wire loose in breaker box. Turn breaker on-off and listen for crackling or fizzing sound, and burned smell. Test breaker for 220Volts. Test top two screws on upper thermostat to see if water heater has electricity.
3) Bad upper thermostat. Replace upper thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
4) Bad upper element. Test upper element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
3helpful
My water is not getting hot
Under the top cover on the side of your water heater, cover's a thermostat that has a red reset button that may be tripped. Press it to reset.
If you have access to a wire tester to test electricity coming into water heater. Check your breaker box for a tripped breaker and power to element's..
Below is a link with information about water heater's that will be helpful to you.
http://www.water-heater-repair-guide.com/waterheaterthermostat.html
http://www.water-heater-repair-guide.com/electricwaterheatertroubleshooting.html
1helpful
No hot water. Circuit breaker not the problem. Which plate do I open to check the eco?
Remove access panels on water heater's side the top thermostat has a red reset button on it.
Press reset button and it will take about 30 mins or more to get hot water. If you have a meter or test light check wires to elements for power.
This would be the first thing to check on the water heater.
Cannot get hot water
Make sure breaker is turned on. If that isn't it tell me model number and maybe I can help you more
Electric Bosch tankless water heater wont heat water.
Here is the run down>
Water too cold Neon light on:
Cause:
1). Water flow is too high-adjusting the water flow as follow; open fully both inlet and outlet shut-off valves at the heater, then turn on fully the highest flowing hot water faucet closest to the outlet connection. Adjust the outlet shut-off valve until the water flow from the hot faucet corresponds to the approximately 3.6gal/min at 105 degree.
2). One of the power supplies is not on-check the breaker box, there should be three ganged breaker, each corresponds to each of the heater power supply.
3). The power supply voltage has dropped-reset the breaker in the breaker box.
4). Temperature dial is turned too low- temperature adjustment is made using the dial on the bottom edge of the unit. The adjustment is between approximately 95 and 135 degree F. Turning the dial clockwise increase the temperature settings.
5). The inlet water temperature has dropped-readjust the temperature dial.
Attached link is for Bosch hotwater heater installation. This should give you idea as to what to look for.
http://www.boschhotwater.com/Portals/7/TechManuals/AE115_AE125_English.pdf
The following link is Basch Hotwater troubleshooting Q&A, this should also give you some help.
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/PowerStarModels/AE115AE125/Troubleshoot/tabid/632/Default.aspx
Please post back on this thread, If you still having problem.
Top Bosch Water Heaters Experts
john h
ZJ Limited
ZJ Limited
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
