GE Profile JGP636 Gas Cooktop Logo
A
Anonymous Posted on Jul 13, 2014
HOW DO ON GET TO THE SPARK MODULEON MY GE MONOGRAM COOKTOP
I CANT ACCESS THE SPARK MODULE
5 Related Answers
Anonymous
  • 999 Answers
  • Posted on Jun 20, 2009
SOURCE: GE Cooktop burner doesn't click or light.
Remove all the burner heads and lift the top. Sometimes easier said than done. How do you know it is the module? It could be a cracked insulator on the ignitor. To verify you can swap two of the connections on the module and if it lights then it is the module.
eric
meztang
meztang
  • 112 Answers
  • Posted on Jul 21, 2010
SOURCE: all 4 electrodes spark when only one is turned on
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Anonymous
  • 43501 Answers
  • Posted on Aug 19, 2010
SOURCE: Problem with electronic ignition on GE Monogram
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Anonymous
  • 43501 Answers
  • Posted on Aug 21, 2010
SOURCE: how to install GE cooktop spark module WB21X10029
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Anonymous
  • 43501 Answers
  • Posted on Aug 30, 2010
SOURCE: GE Monogram gas cooktop electric ignitor will not
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
heatman101
1helpful
GE Monogram f160 error code?
When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
Touch the CONTROL LOCK pad.
Disconnect power to the cooktop and then reconnect.
If an F-code appears again, call for service.
1helpful
Where is the spark module for the GE Monogram Gas Cooktop Model ZGU375NSD1SS located? All 5 burners work, but there is a constant click, click, clicking that sounds while they are in use... :( So I already...
Hello, refer to the next web page: partselect.com/. then select the part blow out for cooktop box components, I believe item number 28 is what you're looking for. Hope this helped.
Jun 28, 2010 • Cooktops
4helpful
I have a GE Monogram Gas Stove - 5 burner. All
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
w3
3helpful
Problem with electronic ignition on GE Monogram gas cooktop. Won't stop "clicking"
heatman101
Feb 27, 2010 • GE Cooktops
1helpful
GE Profile nat gas cooktop, Model No JGP636BEV3BB won't ignite
If you can hear the clicking sound but are not getting a spark then there is probably a short in the ignition system. Check for any loose wires on the ignition system. Make sure all the wires are properly seated. Make sure the spark module is properly grounded. As far as testing the spark module it should be generating a spark of course. The problem is that the average voltage for the spark module is 15,000 VDC so actual testing of that voltage can be difficult. Is the spark erratic?(should spark evenly). An erratic spark timing is a sign of a bad spark module. Is the spark slow? Check the polarity of the electrical plug. If it is clicking evenly then it is probably arcing somewhere inside the cooktop and you just need to find out where. Also be aware that if you get water into the cooktop that can cause possible grounding of the spark module or ignition system.
1helpful
NO cooktops will fire (ge monogram). All sparks stopped at once.
The problem is the spark module has gone bad. See this post for a similar electronic ignition cooktop for tips on how to solve your problem:
http://www.fixya.com/support/t1445987-mgc5430_none_burners_spark
Dec 25, 2008 • Cooktops
One burner requires a match to light
had same problem. Used fine sandpaper on the little head (just above the white ceramic) that creates the spark. over the years the edges of the littel metal ring had gummed up but a 1 min sanding got it down to shinny metal and it sparked nicely.
Top GE Cooktops Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
