Garden Logo
A
Anonymous Posted on Jul 13, 2014
Homelite string trimmer cs 26 model UT 32600 has no spark
roeb
Level 3:
  • Homelite Master 819 Answers
  • Posted on Feb 05, 2019
roeb
Homelite Master
Level 3:
Answers
819
Questions
0
Helped
385104
Points
2343
Remove wire from ignition switch to coil and try, these switches go bad. If not problem you may need coil.
5 Related Answers
Anonymous
  • 246 Answers
  • Posted on May 14, 2009
SOURCE: Hard to start
Hello judy_keough2:
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade and for Chainsaws and Trimmers they Do Not Bog DOwn Under a Load. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Anonymous
  • Posted on May 16, 2009
SOURCE: Replacing the bump head on homelite string trimmer
undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
Anonymous
  • 6 Answers
  • Posted on Jun 19, 2009
SOURCE: Correct gas to oil ratio for Homelite Mighty String Trimmer Model
most trimmers are 50:1. or 40:1. i would use synthetic 2 cycle oil and use the 50:1 ratio. i know guys with trimmers that require 50:1, and they use synthetic at 80:1 with no problems for years. they say the engine runs cleaner. i am a part-time lawn care operator.
Anonymous
  • 508 Answers
  • Posted on Jun 22, 2009
SOURCE: Homelite Trimlite String Trimmer. String won't advance on tapping
remove assembly clean with soap and water and toothbrush(make sure when you dissasemble make notes of how to put back together!)Check spring make sure not broke or distorted-oil with silicon oil(walmart sells or auto parts store)reassemble reverse of dissassemble!!! hope this helps you!!!!
Anonymous
  • Posted on Jan 09, 2010
SOURCE: Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
Homelite ST-80 String Trimmer. How do you remove the air filter cover on a Home lite st 80 trimmer?
Question edited for clarity.
It looks like it pulls or twists off. There are no fixings. It is shown on Page 4
Diagram(s) and/or PartsList(s)
mymowerparts.com https://www.mymowerparts.com > pdf > Homel...
ST80 String Trimmer UT-20507-A. Page 1 of 8. For Homelite Discount Parts Call 606-678-9623 or 606-561-4983 www.mymowerparts.com ...
8 pages
May 10, 2022 • Garden
I took my homelite trimmer apart to replace the clutch, but now can not get the engine housing to go back on, is there a trick to this ? Model ut33600a
Hopefully this will help if not go to homelite.com ordreing parts then select homelite then string trimmer then find your ut 33600a
ST200 trimmer. What kind of spark plug to get and what size string does it take?
Hi Cherri,
I think this is the manual for your machine. It should tell you all you need to know:
file:///C:/Users/Jim/Downloads/Homelite-String-Trimmer-Parts-Manual-ST200-String-Trimmer-UT-20501-A.pdf
Good Luck!
Jim
Homelite y 2500 yardmachine trimmer
http://www.odref.com/homelite/string-trimmers/ut-20612r.PDF
Need to know the spark plug gap for Homelite 25cc Model UT-20779
The spark plug gap should be set at .025 to .030 inches for trimmers. Try to set gap closer to .025.
1helpful
Blade jams can the blade be changed model ut 44110 homelite
After inquiring with Homelite's parts distributor, I have found out the Homelite does NOT offer any service repair parts for this model. A little bit of research tells me why. Home Depot retails this unit for less than $30 here in the USA. To compare, replacement blades for a similar product made by Poulan/Weedeater sell for $26 plus shipping. My guess is that Homelite considers this a disposable unit.
If it was working well for you, go buy another one. For $30, you can't go wrong.
2helpful
2answers
NEED TO REPLACE SPARK ARRESTER ON HOMELITE LITE 26CC STRING TRIMMER
Remove the Torx screws holding the rear cover on. Then remove the larger Torx screws holding the muffler on to the exhaust port of the cylinder. There will be a gasket there. The spark arrestor will be mounted in the opening to the muffler. You can scrape or burn the carbon off of it. If the spark arrestor is real clogged up, then the muffler probably is too. It should also be cleaned. The inside of the engine probably is carboned up too( if arrestor and muffler are). They all should be cleaned of carbon. It helps the engine perform at its' best and breathe like it needs to.
Can not get it started.
have you tried to replace the H T lead?
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
