Take a look at the bottom of page 62. It has instructions for cleaning your bobbin basket (it holds the bobbin case), as well as how to get the case back in. There is a projection on your case on the lower right; that projection MUST rest against what is called (and pictured there in the bottom drawing) the cushion spring. The top of the bobbin case that goes under the needle is the only flat part. When putting in the bobbin case (mine are very similar), I have found it helpful to insert it slightly counterclockwise of the spring, making sure the case is flat in the basket, then twist it counter clockwise so that the projection is against that spring. While your case is out, be sure to CLEAN that area thoroughly with a q-tip (I put a drop of sewing machine oil on the two ends of the swab to help pick up lint), taking care to get under the lip of the bobbin basket, where a lot of lint can accumulate, and then put ONLY one drop of sewing machine oil in the hook race and the center where it is indicated in the manual. After you have replaced the bobbin case but before you have put a bobbin in it, turn your hand wheel TOWARDS YOU (ALWAYS towards you, for anything) several times to distribute the drop of oil. The race is between the outside of the basket, and the metal hook surrounding the basket, and the indicated place is the only place (with the needle all the way up) where you can get a drop between them. It's also possible that lint or other debris--like pieces of threads--are preventing the case from seating correctly.
SOURCE: JcPenney 7064 , bobbin case, bobbin and manual ??
i was able to find it at www.ifixmachines.com
SOURCE: how do i replace the bobbin case in singer machine
When you insert the bobbin case, make sure the "knub" on the bobbin case (#1) is just to the left of the position finger bracket (#2). It should sit in there nicely and you should be able to spin the hand wheel freely.
Let me know if you need more help,
Chris
SOURCE: the casing that the bobbin sits in is out how do I
put the bobbin in its case then pull some thread out and pass it thru the bobbin case slot and under the tension spring .. put the bobbin and case over the shaft that is in the main unit .. the open side of the case goes in first .. make sure the bobbin doesnt fall out .. rotate the bobbin case until its finger lines up with the notch in the main case .. the bobbin case should latch in place on the shaft notch .. place the top thread under and to the back of the pressure foot then turn the machine one turn .. that will loop the top thread around the bottom (bobbin) thread ... now use a card or screwdriver to push both threads from under the pressure foot toward the back of the machine ..
SOURCE: Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
SOURCE: Singer 2662 bobbin case keeps popping out.
Check our bobbin for burrs and damage. If the thread catches a rough edge it can pop the bobbin out. Try a different bobbin with new thread... see if that helps. If it does your current bobbin is likely trash.
Hope that helps.
