Tablets & eReaders Logo
c
charles coombs Posted on Jul 13, 2014
Plt7044k-c how to get service
2helpful
3answers
Can club members play pogo game on iPad.
Pogo Games customer service 1-845-582-1921 pogo Customer Service Phone Number 24/7 Customer services online pogo phone number usa
1helpful
The Google play services are not working on my Tablet, how can I fix this?
Google Play Services needs to be updated from time to time. It seems to keep getting bigger and bigger. You can go into Settings - Apps and then ALL and scroll to find Google Play Services and then click on it. The screen that comes up will give you the option to clear the cache and clear the data.
First clear the cache. Then see if that solves the problem. Likely it won't. Then you can clear the data. It that doesn't work for you then click on *uninstall updates.* This will reset the Google Play Services to original factory. Reboot and make sure you have a good wi-fi connection as the Google Play Services should connect to the Google Play Store and update automatically. If it doesn't, then open the Store app and select *My Apps* *All* and scroll to Google Play Services.and click *Update*.
Note: the Store App, itself, might be slow and balky until the updated Play Services is installed and running.
Here's a hint. If you do the above and delete the updates from the Google Play Services app on your device, when you boot up your device might act balky - just give it a few minutes as it's probably connecting and downloading the Google Play Services updates automatically. Google Play Services is important for just about everything that communicates with Google so don't expect all the other Google apps to work until the updated version of Google Play Services is installed and working.
PROSCAN TABLET MODEL PLT7044K OWNERS MANUAL
You can try a factory reset but your personal data will be lost
6helpful
I have to reset a proscan tablet plt7044k that is locked up with a pattern password that i have forgot do you know how toreset it
Steps on how to reset the Proscan PLT7044K 7" android tablet.
1. Hold down the power and volume up buttons at the same time until you see the android logo then release both buttons.
2.Hold down power button then push the volume up button once for the reset menu to appear.
3.Use the volume down to select the factory reset to reset all data.
4.Reboot the device after reset has completed.
How to connect to the internet
SETTING UP A BROADBAND CONNECTION
First you need to decide what type of broadbandservice you require and these are -
1. DSL that uses your existing telephone line.
2. Cable that uses a cable service and can include a cable TV service.
3. A wireless 3G network which uses the mobile/cell phone network and can beseparate or combine with your cell phone account
Note - Combined services generally offer discount pricing and may include amodem/wireless router.
If you use a wireless router with the DSL or Cable Internet service and yourlaptop has a wireless card then you can also connect to the Internet at WiFihot spots like McDonalds, Star Bucks, the Airport etc.
If you use the wireless 3G wireless broadband service, then you can access theInternet anywhere where your ISP has 3G wireless coverage. You need to checkthe service coverage area where you need Internet service.
Once you decide what type of broadband your require, then you need to checkwith the various Internet Service providers to see if they can offer and thecost of the various plans.
Note the download limits and the associated additional costs if you exceed themonthly download limits. Once you sign up with a Internet Service provider,their documentation will include setting up instructions and/or installationCD.
Device manager not work properly & Modem not found
Check if the service is running, enter msconfig in the Start => Run box. Open the Services tab in the System Configuration utility's window. If the Plug and Play service isn't listed, uncheck the option in the box beside Hide All Microsoft Services. The option for the Plug and Play service should be enabled and should be shown to be running. If it isn't running, right-click the My Computer entry on the Windows Start menu and choose Manage. On the Computer Management window, expand the entry for Services And Applications and click Services. Make the Standard tab display its contents and locate the entry for Plug and Play. Double-click this entry and set the Startup type to Manual. Next, click the Start button under the Service type in the same window. The service should start, and the window can be closed. Should any warnings appear during this process, just click OK. The Device Manager should now be displaying all of its information
Please rate this fixya
Top Proscan Tablets & eReaders Experts
 Mikey
Mikey
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
