I have frequencies on bank one it does not scan othe banks 2-10 banks
SOURCE: Scanning programmed channels
Not exactly. You can program channels however into the Private bank. To do so though you must search for the channel first...This may simply mean going to a channel you already know by using the band button to start searching...Push the hold button to stop it close to the frequency and then use the arrow keys to get to the exact frequency. then push the Prog button. After pushing it, push the Private button (you will see CH next to the frequency) using the arrow keys select the channel you want to store on and push Prog again. To scan the stored channels simply push the private button...Done! It can be a tedious process...expecially with 50 channels....but It's the only way I know how to do it...Good luck!
SOURCE: Only one bank blinks
Yes that sounds like the case. Every scanner or radio I've ever delt with that is the way it works. Check user manual on how to turn off and on banks. Good Luck.
SOURCE: How do I program conventional frequencies into my
Just go to Bank C or anything after that and start entering -- one channel, one frequency. It's kind of cumbersome to do by pushing the keys, but it works. An alternative is to use the BuTel software. It will simplify programming and give you Virtual Control of the scanner through your computer.
If this helps, please give us a rating. A "very helpful" would be greatly appreciated.
SOURCE: I have programmed 10 channels in bank one but now
Hi, my name is John, Welcome to FixYa. Find where you programed the frequencies, press HOLD, then press SCAN. Thanks for choosing FixYa....John
SOURCE: My Uniden BC92XLT will not
Does it just sit on one frequency? and not scan any others? and if you turn the volume up all you get is white noise?
