When i turn on my phone home screen freeze and wont slide
SOURCE: I just purchased a new HTC Inspire 4G cell phone
Thanks for visiting FixYa!
Just a note:
HTC Sync cannot be used for file transfers of music and videos.
To do that, you need to remove your phone's memory card - insert it in a PC - download the Music/Videos to the PC - then transfer them to the memory card.
SOURCE: my HTC inspire 4G won't turn on or charge. the
Was going through this article. It might help:
http://community.htc.com/na/htc-forums/android/f/113/p/9281/40043.aspx
SOURCE: I need a basic manual for my new htc inspire hd 4g phone
hiya
found one here
http://member.america.htc.com/download/Web_materials/Manual/HTC_Inspire/110302_Ace_ATT_WWE_UM.pdf
hope this helps
John
SOURCE: how can i get pc suite for my htc inspire 4g
Download HTC Sync and install it on your PC. It enables synchronization of Outlook contacts and calendar, as well as your media files (music, video). Prior to connecting your phone to your PC through a USB cable, on your phone, go to 'Menu > Settings > Applications > Development', and make sure you select 'USB debugging'. At the moment you connect your phone, you will be prompted to chose the USB connection type. Select 'HTC Sync'.
Hope it works for you.
Anyway, please, let me know if you need further informations.
Regards,Carlos
SOURCE: NEED A.T.&T. UNLOCK CODE FOR MY HTC INSPIRE 4G CELL PHONE
hi to purchase codes visit unlocking4u.com here they ask the imei number of your mobile .finally they send you codes to unlock your mobile along with the instruction about how to use codes in your mobile.
Please note that all data will be deleted from the HTC Inspire 4G as a result of this procedure. This process may or may not delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
First, try this:
If that doesn't work, or if your phone is frozen:
All data including third-party applications will be deleted from the HTC Inspire 4G. Once the wipe is complete, the phone will reboot to its factory fresh state.
