Board - D915GAV
Processor - P$, 3 Ghz
RAM - Hynix 512 X 4
HDD - 2 IDE
DVD - 1 SATA
SMPS - 300 W
Nothing happens when I press the power button. No lights no fans spinning, No post screen. I have checked the SMPS, the RAM, the processor, the drives individually with my other PC. please suggest something
You need
to perform a quick check of the following steps for us to understand the exact
status of your SMPS(power supply) and Motherboard
1) Open
the CPU and check whether the green light is glowing on the motherboard when
power is given to SMPS.
2) Please
make sure that the HDD IDE/SATA and power cables are plugged in properly on
both ends.Use common sense to check, do not press very hard as the slots are
sensitive.
3) Make sure that all the CD/DVD drives are on IDE
2 or on SATA
4) Make sure that the Jumper setting on the back
of the HDD is set to MASTER. NA for
SATA.
5) Login to bios and make see if you can find the
HDD from the drives menu. From Boot menu select the NATIVE mode that will
activate both the SATA and the IDE channels.
6)Check the RAM are tightly inserted in the slots.
Close the box and restart PC
You need
1) Open
2) Please
sensitive.
2 or on SATA
SATA.
Now restart the PC and see what you get.
You need
1) Open
2) Please
both ends.Use common sense to check, do not press very hard as the slots are sensitive.
2 or on SATA
of the HDD is set to MASTER. NA for SATA.
If you feel that, my answers have helped you getting
solution to your problems then please give a vote. Thanks.
Yes,Specs says that it has SATA controller:
Product Description: Sony VAIO PCV-RS602 - P4 3.2 GHz
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
"I have checked the SMPS......." SMPS - Switched Mode Power Supply. Yes Sir, I checked it. As a matter of fact, that's the first thing I checked. How? Well, I have two other PCs. I disconnected this one and checked with another MB. Also, i tried the other two PSUs with this motherboard. And was greeted by nothing but silence.
Yup. Power Button wires are connected to the correct pins. I even tried shorting the pins to get boot. (The thing you normally do when you "bench Test" your PC outside the case.
Thanks for trying though, dissolu. Do you have any other suggestions?
