Depending on the model of your ipod it will differ
iPod Classic password
This
works on an iPod 5 th gen
Click
start control panel scroll to folder options tick in the box to show hidden
files and holders
connect your Ipod to your computer
Click
start click click on you Ipod to open
then go Ipod controls device there should be a folder saying
locked
Right click select rename to open or delete the folder your Ipod should now be
open ipod touch password Launch the iTunes program on your computer and click
"Help" on the main menu.
Scroll down and click "Check for updates."
Close iTunes.
Connect your iPod to the computer using the supplied USB
cable.
Launch iTunes, which will display your iPod on the left
panel.
Right-click your iPod in the iTunes program and click
"Eject."
Close iTunes and detach your player from the computer to
unlock it. http://www.youtube.com/watch?v=5uT8Utk5Tqg
ipod iphone ipad password reset Unlock an iPod Model A1199
Although the second generation iPod Nano (also known as 2G)
uses a four-digit pass code that prevents unauthorized access to your iPod by
locking the screen, you can also unlock the device by plugging it into your
computer's USB 2.0 port.
When the 2G iPod Nano is connected to the computer it is
synchronized, and automatically unlocks the screen according to the official
Apple site.
In order to successfully unlock the Nano it must be plugged
into the primary computer used for synchronizing content.
Click "Start," "All Programs" and "iTunes" on
your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
Plug the iPod Nano's cable into the docking port on the iPod
Nano.
Plug the other end into the USB port on the computer to open
iTunes.
Click "Controls" at the top of the iTunes' menu,
and select "Eject iPod."
The iPod Nano's screen will be unlocked once it
is ejected from your computer.
b> IPods are the most popular MP3 player used. The Apple product is compatible with Mac computers and PCs as long as the appropriate programs are used. In order for an iPod to be used, it must be recognized by your computer. At times you may need to do a bit of troubleshooting, but overall, this is an easy task when these steps are followed.
Download iTunes from Apple for free. ITunes is the program needed to use an iPod. The download is safe and will not give your computer a virus. Plug the white connector cord that came with your iPod into the iPod and into the USB drive on your computer. Open iTunes if it does not automatically open when you plug the iPod into your computer. ITunes should automatically recognize your iPod. Unplug your iPod from the computer. Move the toggle reset button at the top to "hold" three times. Then hold the center button and play button to restart the iPod. Repeat steps one through four. If iTunes does not recognize your iPod, unplug the iPod from your computer. Let the battery die. Charge the iPod and plug it into your computer. The computer should recognize the iPod. http://www.apple.com/itunes/
Sometimes your iPod fails to display in iTunes, which will keep you from being able to transfer songs from your computer to your iPod. If this happens, there are a number of steps you can take to resolve the issue. Is it the iPod? Your iPod could fail to show in iTunes for a variety of reasons and this issue can be resolved by something as simple as rebooting your iPod. To reboot your iPod, first lay it on a flat surface. Using your thumb and index finger, press the play and menu button at the same time. If done correctly, your iPod screen will go blank and then you'll see the Apple logo. Is it the USB cable? Your iPod could fail to show in iTunes if you are using a defective USB cable. Try connecting your iPod to another computer that has iTunes installed using the same USB cable. If iPod again fails to show in iTunes, replace the USB cable. Is it my computer? One of the most common reasons your iPod doesn't show in iTunes is because your computer doesn't recognize your iPod is connected. Troubleshooting your computer/iPod connection Disconnect your iPod from the computer and reconnect. If your iPod still doesn't appear in iTunes, disconnect your iPod and reboot your machine. Once your computer has restarted, reconnect the iPod. Is it iTunes? Your iPod could be fail to display in iTunes if there is a issue with your iTunes program. If there is a problem with iTunes you can try updating the software to the most recent version. If that doesn't resolve your problem, re-install iTunes. b> http://www.itunes.com/ b> http://www.apple.com/support b> iPod Won't Connect to iTunes b> Apple's iTunes software contains mechanisms specially designed to sync with your iPod, allowing you to transfer music, videos and other media from your computer. If you find that iTunes does not recognize or allow you to access your iPod, then you cannot perform some of the device's most fundamental functions. Fortunately you can often resolve this problem without expensive maintenance, simply by doing a bit of troubleshooting and determining the cause of your connectivity problem.
Try resetting your iPod. Apple recommends this as a first step in troubleshooting an iPod not appearing in iTunes, since a quick reset will often restore functionality. If you use a click wheel iPod, hold down the "Menu" and center buttons until the Apple logo appears on your screen. For the iPod Touch, hold your "Home" button and "Sleep" button simultaneously until the Apple logo appears. Charge your iPod battery. If your battery has absolutely no power left, your iPod will often remain unresponsive even when plugged into iTunes. Try charging for three to four hours and then try connecting again. Plug your iPod into your computer using a different USB port. Sometimes a failed connection can mean you have a faulty USB port, so try plugging your USB cable into a different port and see if the iPod appears in iTunes. Verify that you have the latest version of iTunes. Visit the iTunes page Apple.com and check to see the latest version available. If you do not know which version currently runs on your computer, click "About iTunes." For Mac users, this option will appear under 'iTunes" on your menu bar. For Windows users, the option will appear under "Help" on your menu bar. Download the latest version of iTunes if necessary. Reconfigure your iPod service. If running iTunes on a Windows computer, click "Start > My Computer > Manage," and select "Services and Applications." Under "Services," select "iPod Service" and click "Stop." Leave the window open and connect your iPod to your computer. When your iPod shows up on your computer, click "Start." Reinstall iTunes. If simply updating iTunes does not work, you may have defective software. Try removing the program from your computer and completely and reinstalling it.
First, and most obviuos, plug in your iPod. iTunes should automatically pop up and recognize your iPod shuffle. How many gigs can it hold? When you plug in your iPod to your authorized account, you shuold automatically see iTunes transferring songs into your iPod.
If not, manually transfer songs into your iPod. Select your iPod on the left hand panel of iTunes, where you can look into your iPod. Next, look at the menu that pops up when you click your iPod (it shold show you your iPod, how mny gigs it can hold, etc.). Click 'Manually transfer songs'. From there, you can choose which songs to download into your iPod from iTunes (whichever songs are checked in the little boxes on the left of your songs in your iTunes).
Go on to itunes and plug your mp3 in to your computer and download it and salect which tunes you want. If it dose not work
there is somethind wrong whith your mp3
I recommend you am iPod to iPod/Computer/iTunes Transfer which can transfer your iPod and iPhone music, video, playlist, photos back to computer and iTunes.
If you own more than one iPods, AVCWare iPod to iPod/Computer/iTunes Transfer can simultaneously manage all the iPods in the same interface, you may transfer files among these iPods by drag-and-drop.
To me, it sounds like maybe you have the ipod plugged into your computer, you have itunes open and instead of clicking on the MUSIC portion of itunes, you are in the actual ipod's portion that comes up when you plug the ipod in.
To make this process easier, you should try unplugging your ipod and deleting the songs you don't want from your itunes without your ipod plugged in. Once you have deleted the songs you don't want, try plugging your ipod in. You can't delete songs directly off your ipod.
Hope this helps! If not, you might want to consider calling apple.
Try this: turn off your ipod, hold the home button, and plug it into
itunes while still holding the home button until a picture of the itunes symbol
appears with a cable under it. itunes should say "ipod found in restore
mode". This will completely reset your ipod, hopefully fixing any bugs or problems in it. also, you will lose all data saved on the ipod that isn't also backed up by itunes. Music, pictures, and video can be re-synced.
