NovaLogic F-16 Multirole Fighter for Windows Logo
A
Anonymous Posted on Jul 12, 2014
Why f16 session creation error ? - NovaLogic F-16 Multirole Fighter for Windows
Ivan
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Jun 01, 2015
Ivan
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
3291
Points
49
There are several protocols programs use to comunicate, old games like F-16 uses IPX, which may not be installed by default in your operative system. In XP you may install it in properties of conection, in newer systems you will require to download such protocol. Remember, IPX.
What does 'SSL communication cannot be performed a handshake error has occurred in SSL' mean?
The Secure Sockets Layer (SSL) protocol uses a combination of public-key and symmetric-key encryption. Symmetric-key encryption is much faster than public-key encryption; however, public-key encryption provides better authentication techniques. An SSL session always begins with an exchange of messages called the SSL handshake. The handshake allows the server to authenticate itself to the client by using public-key techniques, and then allows the client and the server to cooperate in the creation of symmetric keys used for rapid encryption, decryption, and tamper detection during the session that follows. Optionally, the handshake also allows the client to authenticate itself to the server.
If you get the error you can do the following
1. Go to your internet options
2. Go to security settings tab
3. Click on Trusted Site's
4. Add https://THE NAME OF WEBPAGE YOU A GETTING ERROR FROM
5. Go to Advanced tab
6.Scroll down to USE SSL 2.0 and USE SSL.3.0 make they are both selected and click Apply button at the bottom
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
What does error F:16 indicate?
It would be helpful to know tha make and model. Different manufacturers use the same code for different things. Can't tell from the picture (It looks a bit ike a Whirlpool)
Error: F16,
Machine: Washing machines & Washer Dryers,
Type: Standard,
Fault: Water level far too high. Check pressure switch, pressure hose (for blockage or disconection)also the pressure chamber for blockage
Error: F16,
Machine: Dishwasher,
Type: Bosch EXXCEL,
Fault: Door not closed. Check door is closing properly or door switch.
Error: F16,
Machine: Washing Machine,
Type: whirlpool (not every model),
Fault: Faulty control unit.Check wiring connections, replace unit.
Error: F16,
Type: Dyson CR01,
Fault: Motor fault.(Faulty triac).Check motor and associated wiring, check module and connections Faulty tacho. check tacho and associated wiring, chech module for loose or defective connections.
Error: F16,
Machine: Washing machine,
Type: Bosch WFP Series,
Fault: Rinse sensor is fault.(This error code will only show up in test mode).
What can I do when I have Error 15
Hi We are KRN Technology From sri Lanka. I can give instruction to slove F16 error and save your money.
First Remove top cover and disconnect drain heater connection . joint 15k 2 watt Resistor bitween Heater connection and insulate it.
Now you can run your washing machine without F16 error.
If you want to use drain heater you have to buy drain heater and fix it. Then no need to connect 15k resistor.
Bye all.
I am Neville
From KRNTechnology
2helpful
2answers
F16 error code on washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board.
Whenever I try to do a LAN multiplayer game it will say Session Creation Error
I was able to create a LAN game, and to see the game in the list in the another computer, but this one is unable to join the game, it starts usin all the CPU power. What I did to reach this situation, instead the "session creation error" was to install a required protocol: Control Panel - Net conections - (the conection that you use (double click)) - properties - install - protocol - NW Link IPX. Hope it to help a bit.
Whirlpool Duet
your main processing board is having an communitcation error. if you have taking the kickplate off the tech sheets or on the right or let hand wall and will tell you how to enter the diagnostic phases
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
3helpful
F16 error
constant f 16 shown on screen on my Panasonic mini hifi set what the problem.,
Top NovaLogic Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a NovaLogic Video Game Console and Game Expert? Answer questions, earn points and help others
