SOURCE: 6 gallon Husky air compressor won't start
There are a few things that may have happened.
Air compressors have a fairly high draw and you should be sure that it has a proper electrical supply to it. Too small of a cord can cause the two above problems.
Also make sure that your pump is not seizing up.
SOURCE: My husky 2 gallon air compressor is not building
sounds like the compression rings on the piston neen replacing or the none return valve faulty.
SOURCE: I have a model FP209501 Air Compressor 2 Gallon,
The spray gun consumes more air volume than the compressor can deliver. You can pause painting periodically to allow the compressor to 'catch-up' or buy a larger delivered-volume compressor. The compressor that you have was intended to supply air for pneumatic nailers and staplers in an intermittent fashion. Hope this helps!
SOURCE: husky wl651004aj 17 gallon my compressor
There may be a reset button on or near the motor. If you see one push it. Also are you sure you have power at the outlet. In most garages built within the last 10 years all the outlets are protected by a GFCI outlet. Power runs through this outlet to all the others. Make sure it has not tripped. If you have voltage at the outlet where the compressor is plugged in and there is no reset button it has an internal breaker that should reset itself after the motor cools off. If it does not then the breaker may be bad or the on/off switch is bad. To make sure nothing is wrong with the connection at the outlet, plug it into another outlet without an extension cord just to make sure.
