LG DLE2532W Electric Dryer Logo
A
Anonymous Posted on Jul 12, 2014
Dryer runs doesnt get hot changed element thermostst is there s rest im missing
My Kenmore Dryer starts but when I go to check it has stopped. The clothes are hot so it has run for some time I think maybe the safety switch to prevent over heating. I have changed programs and i
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Oct 17, 2014 • Dryers
My whirlpool duet dryer will dry one load of
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Sep 14, 2014 • Dryers
The heating element does not work. I replaced the thermostst part #3390291 and cleaned everything and still no heat.
you have 3 stats on these machines.........
dont just change 1.......the 2 on the back must be replaced as a pair
and fitted to the correct wires....................
check for continuity on the element.....................
cheers
No heat in dryer. changed coil and thermal fuse
You need to check thermal cutoff switch and thermostst mounted on side of heating element box.MAKE sure unit is UPLUGED
Changing heat element on a ge 223 dryer
open the door there are twp screws there remove them take top off then the front remove belt and drum the element is in the back
2helpful
2answers
Not lighting... no hot air at all.
You most likely just have a bad heating element. They aren't usually very expensive and if you take your time you can replace it yourself pretty easily. This is a common condition for dryers and the element is pretty much always the culprit. It only takes an hour or so with minimal basic tools. Screwdriver, crescent wrench and not much else. If you take the back off of the dryer it should be fairly obvios how to do it. UNPLUG IT FIRST!!!!!!
We have a Kenmore Gas dryer it runs but it doesnt get hot.. any ideas what it could be?
The heating element is most likely burned out. Try ordering a new heating element for your dryer and calling a repairman to put the new heating element in.
I have a Kenmore dryer that runs but dries real hot and then shuts off.If I don't open the door or shut it to off, it will come back on, I guess after it cools down. Any suggestions as to what the problem...
do you have any clothes stacked on top of it? If so you are killing your dryer take everything off of it and NEVER use it for storing or stacking anything EVER. pilling the top of it makes it overheat. If this is not the fix then your thermal limit switch is bad and not doing it's job
Maytag performa runs no heat how do I access the heating element?
Well if it runs then the fuse is ok so what you need to do is pop the top and check the high limit thermostst and heating element located at the rear of the machine. The top on most of these machines comes up easilty if you use a putty knife or five in one. Be sure to disconect the power source. a12fee1.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Top LG Dryers Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Dryer Expert? Answer questions, earn points and help others
