Frigidaire ATF6000ES Front Load Washer Logo
A
Anonymous Posted on Jul 12, 2014
How do i unlock a fridgidaire washer - Frigidaire ATF6000ES Front Load Washer
  • Official Brand Answer 2,267 Answers
  • Posted on Jul 15, 2014
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1290045
Points
2557
Hi Friend, this is Z. Thank you for your post!
I see that your question is listed under Frigidaire washer, ATF6000ES. To unlock the controls, press Options and Select at the same time and hold roughly 15 seconds until "LOC" is no longer displayed. I hope this helps!
2helpful
I'm trying to disable the safety on the top load fridgidaire washer because it keeps malfunctioning and not finishing the rinse cycle.
This is something that is designed into the feature of this combo stack unit and cannot be bypassed at this current time - from my research.
Fridgidair affinity washer paused with error code EF2
According to SearsPartsDirect.com ( http://www.searspartsdirect.com/washer-repair/error-codes/frigidaire-front-load-washer-error-codes.html ) : EF2 Condition Too much suds Check/Repair Reduce the amount of high-efficiency (HE) high-efficiency detergent being used in the washer.
The frabic softner dispensor is not releasing the softner in the washer.
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Bleach will not dispense
Here is a tip that I wrote about the problem I found with my fridgidaire not dispensing fabric softner. Hopefully this will help you out...
http://www.fixya.com/support/r5660917-fridgidaire_washing_machine_fabric
heatman101
1helpful
E20 error code fridgidaire washer
A lot of times it is the strainer clogged at the pump. Hope that helps. Tim
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Fridgidaire GLET1041AS1
Unplug unit! Remove top screws and pull off top lid of dryer. Heater terminals should be at top right. Use ohm meter to check resistance. If ohms won't display, then your heater unit probably has an open circuit. For instance, my GLET1031 has a reading of 12.5 ohms.
My fridgidaire washer fillw with water and agitates but it will not spin or drain.
YOUR LID SWITCH IS BAD,POP THE TOP FIND THE WIRE JACK TO SWITCH CUT BOTH OUTSIDE WIRES,WIRE NUT THEM TOGETHER,MADE SURE YOU UNPLUG MACHINE FIRST,YOUR MACHINE WILL NOW WORK BUT WHEN YOU LIFT THE LID ON FILL OR SPIN IT WILL NOT TURN OFF,SO KEEP YOUR HANDS OUT OF THERE,THE LIP SWITCH CONTROLS FILL AND SPIN,THANKS-MIKE
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
