Hi!
Error codes P98-1061 and T98-1061 on the Riso SF5030 indicate an issue with the color drum's motor. This error code usually occurs when there is a problem with the motor or the wiring that connects the motor to the printer's control board.
Here are some steps you can take to troubleshoot the issue:
- Turn off the printer and unplug it from the power source.
- Check the wiring connections between the motor and the control board. Make sure that they are secure and not damaged.
- Check the motor for any physical damage or signs of wear and tear.
- If you have a replacement motor, try replacing the faulty one and see if the error code persists.
- If the issue persists, you may need to contact a service technician to diagnose and repair the problem.
It's essential to note that opening up the printer's internal components can be dangerous, and you should only attempt these steps if you feel comfortable doing so. If you are unsure or uncomfortable, it's best to contact a qualified service technician for assistance.
Regards
