Electrolux EW1200i Front Load Washer / Dryer Logo
A
Anonymous Posted on Jul 12, 2014
MACHINE FLASHING DDO CODE - Electrolux EW1200i Front Load Washer / Dryer
  • Official Brand Answer 2,267 Answers
  • Posted on Jul 21, 2014
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1288948
Points
2557
Hi Friend, this is Z. Thank you for allowing me to assist you!
Generally, error code DDO means that the dispenser drawer on your unit may be open. If so, close the drawer and the error code should resolve itself.
If you've double-checked the drawer and it is closed, remove the drawer and examine the magnet. If the magnet is missing or defective, the magnet probably needs replacing.
If the magnet is fine and in place, an experienced technician may need to examine the reed switch or main control board.
Since there are cost differences in parts and accessories, it is always a good idea to have a service tech properly diagnose your appliance.
Error code DDo ON A FRIDGEDAIRE FRONT LOAD WASHER
Hello geraldinerid - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a further diagnosis is recommended to have a professional check the reed switch.
1helpful
Frigidaire Front load washer with ''ddo'' code
The DDO trouble code means that the detergent(D) dispenser(D) door is not closed properly((O)open).
The door uses a reed switch and a magnet to send the door closed signal to the control card.If the
magnet becomes dislodged you will get this code.You will need to have the magnet replaced in
its proper position to clear this code.
2helpful
Ddo
Hi
This ddo error code means Dispenser Drawer Open.Check to see if the Dispenser Drawer is open or the small tubular Magnet # 51 is missing. The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself, you will see snapping clips to unsnap, then you will see the magnet#8 in diagram#1 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=117979
reference
http://www.fixya.com/support/t2180388-code_ddo
10helpful
Ddo error code on frigidaire front washer
Hi
Thanks for using FixYa. Error DDo means dispenser drawer open. There is a little magnet attached to the right hand side of the detergent drawer which activates a reed switch to "tell" the machine that the drawer is closed. That magnet might have moved from it's place and that's why you are getting error ddo. magnet is part key number 51. Pull the drawer out and check on the handle part for a magnet. When the drawer is closed the magnet activates a switch in the console that tells the control the detergent drawer is closed. Please check this link for details(part #51)--
Frigidaire exploded parts catalog
Please do rate the solution and revert for further assistance.
Thanks
Rylee
8helpful
Code ddo
Hi
This error code appears in the frigidaire washer which means--
ddo error--- Dispenser Drawer Open
GLTF1670AS0
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
4helpful
Error code ddo
the dispenser drawer has a magnet in it that has to line up with a sensor. if you can put the drawer back in that will solve the problem. if the magnet isn't lost.
2answers
Error code ddo will not start wash
This indicates a problem with the door interlock switch and until resolved the machine will not start.
2helpful
2answers
Washer
DDO is dispencer door open
the magnet needs to be put back into the dispencer door the machine thinks the door is open...
let me know
29helpful
2answers
Frigidaire + ddo error code
Excellent solution. I had a similar problem. The trick is to figure out where to put the magnet. I had a hard time with that.
For those like me who might have difficulty finding the spot for the magnet, it goes on the right hand side of the detergent door. The easiest way to do it is to pull the detergent door all the way out of the machine and look at it such that the back of the door is facing you. The magnet fits vertically in a slot on the left side as you are looking at the door (right side of the doorwhen inserted in the machine) in the white plastic. It sits vertically and is held by a small latch. This is not obvious at all...
Top Electrolux Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
