SOURCE: briggs and stratton lawnmower 4horse power engine needegap specs on coil and points
That's easy man! You will always hear, "You sir, need to gap this or that at EXACTLY .00071542 inches per square meter".
The actual "poor boy fix"-
Put your magneto back on there, and stick a business card from your wallet in between it and the rotor. Let the magneto pull itself to it, you center it, and give it just a hair of breathing room (to slide the card back out). Tighten 'er down, and you got it.
1.- If you can't pull the card out, it is too tight.
2.- If you pull the card out easily, too loose.
3.- JUST enough to pull it out, and have it drag just a bit on the way out is JUST ENOUGH!
Remember, on 4-strokes, they ARE forgiving, and can do miracles even if you try your best to destroy them.
SOURCE: need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
SOURCE: Cylinder head bolt torque setting for a
Search Briggs on the Web, You can order Manuals there. The torque is in in. pounds. Need more info ! A just get them tight and all about the same will work, stagger the bolts in the Head when tightening ( one bolt, one side then the other until done.) Then check them all.
SOURCE: I cant find torque specs for a briggs and stratton
WHAT SPECS DO YOU WANT WHAT PART ARE YOU CHANGING
