Brother HL-5240 Laser Printer Logo
A
Anonymous Posted on Jul 12, 2014
Why when page prints it has black ink blotches on it
1 Related Answer
Everett Lin
  • 990 Answers
  • Posted on Dec 13, 2008
SOURCE: MFC-8460N is smearing 3 small
if these 3 blotches line up in same track ,then you have to change you drum unit.
There are black ink blotches when I try to feed envelopes through the rear feeder
use the maintance function on your printer to adjust the ink output level.
1helpful
Printing misaligned color blotches, little squares off to the
Are you using genuine inks or compatibles/refills? Have you cleaned / aligned the print heads recently? Does it only happen on the second print? Could be a case of excess ink getting onto the rollers which then get hot and deposit the ink on the next paper coming through.
Also make sure you've selected the correct paper type before printing.
The printed pages have pink blotches on the right hand side of the paper and horizontal pink blotches down the page
Try cleaning the color or magenta cartridge with rubbing alcohol and look inside the printer to see if there's pooled ink anywhere that is smearing on the paper. Try replacing the print head or cartridge.
Paper jams w/ all types of paper, Ink blotches...
If you're getting spots on the prints, run the Remove Ink Smears routine in the maintenance. It will clear the ink from the preheater. User packing tape to pull dust off of pick rollers. It's easy to unclip the unit and roll it on a piece of tape to remove dust.
Ricoh cl3500N printing with blank streaks in middle of page and faded quality black printing and black ink blotches on sides
The voids and blotches can be a bad black pcu, the voids san also be toner on the glass slat obove the pcu,s there are 4 slats one for each color, on the pcu itself on the upper side is a narrow long opening, the glass slat is above this opening when the pcu is in the printer. It will take a flashlight to see any toner on the glass.
-Carl
Rows of black ink blotches on my printouts
Found bits of dust adherent to printer heads, took awhile to clean out with fine forceps, but seems fine now
Ink blotches
so the ink cartridge head in hot water for 10 mins, That will dissolve the clot inside the print head. Smudges should be gone. Else get a new print cartridge.
Blotches
you may need to replace the drum,
Left & right streaks when printing
Hi, it sounds that your printer may require service to clean the printhead thourouly.
Tirzo
Printing Problem
SOUNDS LIKE YOU ARE REFILLING YOUR OWN CART. THEY DO NOT WORK WITH BROTHER MACHINE, THE BROTHER MACGHINES ARE SET TO WORK WITH OEM PRODUCTS, CHANGE YOUR INK GOOD LUCK BROTHER TECH
Norman Weimar
Norman Weimar
k24674
