SOURCE: battery won't hold a charge
We have had problems with scooter batteries from time to time and the repair man said to take apart the battery case and disconnect the batteries and use a car charger. I put the two battery in parallel and used a amp battery charger. This worked fine.
Don't run your scooter batteries all the way down when using the Go Go as the scooter charger won't always bring them up to full charge and you may have repeat this. Also running the batteries all the way down shortens there life.
Finding the pump on the Kenmore Elite top load washer is a fairly easy project that can be done in about a half hour. The Kenmore Elite is part of the GE line of appliances and shares many of the same interior mechanical parts and systems. The Kenmore Elite is a very streamlined exterior cabinetry design, but the interior can be accessed by removing just a few screws in order for you to locate the water pump.
things you'll need:
Unplug the electrical cord of the Kenmore Elite top load washer from the electrical outlet before attempting to locate the pump.
Remove the end caps on the control console of the dryer by pressing in on the caps with your thumbs and pulling the caps forward to unfasten them.
Unfasten the screws on the ends of the control console in the front with a screwdriver and tilt the console back so that it rests on the back hinges.
Unplug the top lid switch from the rear of the lid that sits underneath the control console, pulling the switch straight up off the metal prongs by hand.
Pry the metal clips that sit on the top lid up with a screwdriver, lifting the clips to unlatch the top and pull the top lid cover off the washer base, setting it aside.
Locate the water pump at the base of the washing machine on the top of the motor shaft.
7
take the cover off the pump and remove any blockage or debris.
thanks and good luck
iain
Read more: How to Find the Pump on a Kenmore Elite Top Load Washer ' eHow.com http://www.ehow.com/how_6304872_pump-elite-top-load-washer.html#ixzz1LQ4bdiFZ
Top Shot Elite Set Up and Usage Guide by Activision
Follow this link to the Guide on Facebook.com/ActivisionHunts
Also see the following Expert Videos to have the best gameplay experience with your Top Shot Elite:
Top Shot Elite How To Video 1 - Introduction
Top Shot Elite How To Video 2 - Syncing
Top Shot Elite How To Video 3 - Calibration
Top Shot Elite How To Video 4 - Dead Zones
