Hi all! I have disassembeled the wand to the point, where i took off the plastic cap and just have the head piece on a spring in my hand. How do i disassamble it further? Problem is the motor seems to be working fine but no vibrations come through.The metal ring and the plastic ring are lose too and I have unscrewed every screw I could see. Any help would be appreciated.
SOURCE: Sounds like its working, but nothing happens
I had the same problem with mine, it's due to the fact that the smaller spring has become un-lodged from the ******** itself.
You will need:
1. Roll of electrical tape.
2. Utility Knife
3. A small slot head screw driver OR a pair of needle nose pliers.
The solution is to unscrew the silver ring so that is can be moved up
and down. Now, you need to use a utility knife and cut the blue rubber
off of the spring. Once you have the blue rubber but off you can see a
large spring with another smaller spring inside. Push the head of the
******** till the larger spring's coils are an 1/8 to 1/4 of an inch
apart. Next take either the small slot head screw driver or a pair of
needle nose and jam the smaller spring back into the hole in the center
of the white plastic piece inside of the larger ring. Next plug it in
to make sure the vibration is working, reattach the silver piece and
tape the larger spring with electric tape.
SOURCE: the small spring inside my
Hello there, Hitachi does not provide support for this product parts wise.To get a replacement spring you would need to get the spring from the nearest hardware store available to you. Basically what you need to do is determine the size of the spring and you can easily get a replacement spring from the nearest hardware store. Usually it is recommended you take the unit there so you can get the exact size needed. Other than this you can get the spring size and order a replacement spring online from amazon or ebay or any hardware website in your locality.
Hope this support has been helpful?
Thank you for visiting FixYa.
SOURCE: I fixed my hitachi magic
rotate the head/neck part, one of the sides is not aligned with the notches in the bace of the neck. rotate it to fit right then you should be able to fit it on easily
