New Home MX-3123 Computerized Sewing Machine Logo
A
Anonymous Posted on Jul 12, 2014
Janome 423s works reverse only - New Home MX-3123 Computerized Sewing Machine
1helpful
Model 18w. Why won't it reverse?
If you read a little over halfway down the web page below, you will find another Janome with the same problem. Perhaps it will help:
Repairing Janome or New Home Sewing Machine
Janome New Home mx3123 reverse button not working
Reverse does not work on my New Home Janome Excel 23L
it will only reverse in straight stitching if it's not reversing at all,I'd return!
I have a Janome sewing machine, #423S that I have never used. It is second hand. It sews nicely, but I cannot find the reverse lever on it
The reverse lever should be below the stitch width lever. (It's a wide lever in its own recessed area. just above the level of the extension table.) See page 2 (page 4 of the PDF) available here: http://content.janome.com/documents/File/ManualFile/Inst%20book%20419S%20&%20423S1.pdf .
I hope this helps.
Instruction manual for Janome 419s & 423s
You can download one from here:-
www.sicistroje.net/soubory/.../423S_Instr_book.pdf - United States
I need a manual for a Janome 423S sewing machine
So, I got it on this site:http://content.janome.com/documents/File/ManualFile/Inst%20book%20419S%20&%20423S.pdf
Janome 423S the feed dogs wont come back up
On some of my machines, they are not Janome, when I put the feed dogs back up, they will not Pop back up, until one rotation has been made with the fly wheel.
1helpful
1/28/13 - I have Janome Harmony 2049 that was initially sewing forward with no reverse and then after about 12 inches of sewing would ONLY sew in reverse. After spending an hour getting the plastic housing off...I was able to locate the shaft that made the reverse. It needed lubrication and after working it in and unjamming the part from the down position, the forward and reverse now work!
Huh, right? Hope it continues to work well. It is a smooth running machine, otherwise. Good luck!
Top New Home Sewing Machines Experts
NOEL
NOEL
Paul Bade
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
