Question about Frigidaire FEF336BC Electric Kitchen Range
Sunbeam blanket controller flash - Frigidaire FEF336BC Electric Kitchen Range
2 Suggested Answers
SOURCE:
SOURCE: Binking light on one control of electric blanket (Sunbeam)
I'm not sure how I was registered as having a problem with an electric range; my problem was with my Sunbeam electric mattress pad.
I used one of the suggestions I read here. I unplugged the connection to the mattress pad and blew into the receptacle to clear any dust or lint from it. I reconnected everything, plugged it in, and the problem has been eliminated.
Thanks for the suggestion.
Posted on Oct 06, 2009
My sunbeam heating pad model cat95c is flashing f
unplug replug blanket to control connectors plug back in
this will continue to happen on these blankets you will have to reset these blankets again and again (chinese junk)
Mar 15, 2018 | Sunbeam Heating & Cooling
The 2 controls to our electric blanket are flashing "FF". What does that mean, plus there's no heat at all from it.
With the Sunbeam blankets that I have owned, FF meant that there was a bad connection somewhere. Have you tried the unplugging and replugging the Controller cord back into the blanket? Make sure it is plugged in GOOD AND TIGHT. If that part is connected as tightly as it can go, you may have a defective element.
Dec 18, 2014 | Sunbeam Pac 259 Dual Electric Blanket...
The blanket doesn't heat. It's properly connected. The control box has two LEDs that keep on flashing regardless what I do with the wireless remote. I have two remotes, each one set for single side...
I think the board is burnt out on the unit and is in need of service or replacement through Sunbeam.
One can contact Sunbeam at 800-892-7684 for bedding.
Dec 18, 2010 | Health & Beauty
My husband and i were just recently given the queen size, dual remote heating blanket from you guys. When we try to turn on either of our remotes, it flashes F2 consistently unless unplugged. Is there...
The first link has some info about the F2 code.Apparently it used to be seen as FF but was changed.It is a power problem.It is still the same problem,which is REALLY not good.The next couple of links are forums which people also have the same problem as you.I would seriously get rid of that blanket.I saw someone mention EMF.I know exactly what EMF is and it is not an issue with this blanket at all,and is present in many things.A microwave probably has more,and still is not an issue.Anything that plugs into a wall has some form of EMF present,so do not even worry about it.
http://wiki.answers.com/Q/What_does_the_flashing_code_F2_mean_on_the_Sunbeam_Dual_Electric_Blanket
http://www.consumeraffairs.com/homeowners/sunbeam.html
http://www.complaintsboard.com/complaints/sunbeam-westpointe-amp-jc-penny039s-electric-blanket-c40368.html
http://www.complaintsboard.com/complaints/sunbeam-heating-blanket-c134216.html
Nov 28, 2010 | Sunbeam Heating & Cooling
We have an sunbeam electric blanket model BL 0750 We dont seem to be able to programme it to heat up. Control lights are flashing
Hi. If you have a double or queen size blanket, switch the controls from one side to the other. If the fault follows the control, then the control is faulty. If the fault stays on the same side of the bed, then the blanket may be faulty. Most recent Sunbeam models have 3 years warranty. Once you've checked the controls, if it's under warranty call Sunbeam Customer Service on 1800025059 option 1 to report a warranty issue.
Otherwise: if the control is at fault, a new BL0750 has a recommended retail of $75.20. Get in contact with your local Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
but if all else fails email me as I'm happy to help!
May 25, 2010 | Vacuums
Sunbeam Electric Blanket Model 972 A5 Type 692 (or 592) with temperature control 1 to 9 with 75 mins and 12 hrs and off control positions. The light blinks red and the blanket won't heat up. Please...
Did you get helped last year? If so please ignore. Otherwise....
Hi. You can locate a Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
You're looking at $69,95 recommended retail.
BTW have you checked that it's not the blanket? Swap the controls over, if the problem follows the control it's the control. If the problem stays on the same side of the blanket, it's the blanket.
Also note Sunbeam has a 3 year warranty on electric blankets. If Date Of Purchase is less than 3 years ago call 1800025059 option 1 to speak to their Customer Service,
Apr 08, 2009 | Sunbeam 4237 / 4238 Iron with Auto...
My dual control sunbeam electric blanket flashes on one side
Return this product as it is a fire hazard.
please mark this as a fixya! thanks
Feb 22, 2009 | Sunbeam 4237 / 4238 Iron with Auto...
Frigidaire FEF336BC Electric Kitchen Range Logo
100 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
