Here is the link from where you can buy the genuine Motherboard. In this website there are various models and you need to choose for you model. Instructions are also in the website..
http://www.buymotherboard.net/hp-dv-series-hp-dv2000-motherboard-c-1_18_5.html
Regards
Saran
SOURCE: The hp pavilion dv2000 not booting
You might be still covered under extended warranty, check here
Hook a spare monitor to the video output, usually on the back. If you get a picture it means the inverter board is bad, or the backlight behind the LCD display, check to make sure the round video cable is plugged into the motherboard. But, if the symptom is the same for both screens, the problem is the Video Graphics Card normally built into the motherboard. If the connector to the LCD is damaged that would explain the issue of no video.
