Question about Invicta Subaqua Noma Iii S
How to set date and day on INVICTA SUBAQUA NOMA III
    New Friend:
  • 3 Answers
Pull the stem out 2 clicks sets the time, pull the stem out just 1 click
turn it forward sets the day and turning the stem backwards sets the
date. I hope this helps
Posted on Jul 12, 2014
SOURCE:
mcdevito75
  • 1970 Answers
SOURCE: need a manual describing how to set the date for
mcdevito75 here, Best Bet, online to shopnbc.com to Invicta watches, or give Invicta a call , info at the website at ShpNBC.com
Posted on Jul 04, 2010
gemineye61
  • 831 Answers
SOURCE: Hello, I hope that you
<P>Thank you for contacting FixYa.</P><P>I dont know much about Invicta, however they have a wonderful website where you can download instructions or contact them.</P><P><A href="http://www.invictawatch.com/welcome/manuals/">http://www.invictawatch.com/welcome/manuals/</A></P><P>Best regards.</P>
Posted on Aug 27, 2010
  • 101 Answers
SOURCE: just bough a Subaqua Noma III Chronograph Watch
you cannot fix this. Unfortunately for movements to be that exact they cost a lot of money and the movement inside your subaqua is not that high tech and accurate. This is what makes watch really expensive the little things like this. Unless you are buying a 10k watch , they usually are not going to have the top of the line movement . The movement you have in your watch is an ISA 8173 and that is as accurate as the watch will get.
Posted on Oct 19, 2010
genebur2
  • 63 Answers
SOURCE: What powers my subaqua noma iii gmt limited
It has an automatic movement powered by the movement of your arm.
Posted on Nov 07, 2010
SOURCE: Hi i just got an
I have had the same problem with one of my SANIIIs, As you have probably figured out, there are two small screws that are part of this assembly, lower one is the pivot point, upper is the latch. There are also very small rubber bushings (upper & lower) in the pivot of the crown protector, if they are worn it will present side to side movement or "slop" they need to be replaced in this case (I Just went through this on an older Valjoux 7750 SANIII - same problem, latch would not stay closed), you can order the part from Invicta or take from a donor watch in the mean time (Invicta will take several weeks to months to fulfill a part order) The upper screw goes through a small cylinder or cam, there is a little (very little - but it is there) to move that cylinder outward towards the upper pusher or top of the watch. After you loosen the top screw (loose not remove) you can adjust this play w/two precision screwdrivers, one to tighten the upper screw one to lever the cylinder toward the top of the case by leaning one screwdriver w/ just a slight pressure against the crown and the cylinder to widen the area between the pivot screw and the latch cylinder. Don't overtighten the screws to try to add friction to the assy - the threads & heads are fragile, you can damage the case or strip them - or worse snap the head off. Hope that helps.
Posted on Dec 20, 2010
Watch ******** my invicta 5511 has snapped how do i get a new one
you can find what you need at Invicta Web-site http://invictawatch.com I had order straps from them for my Sabaqua NOMA III and russan diver here is also the link for the service http://www.invictawatch.com/support_files/service_center/ServiceCenter.htm
Nov 16, 2012 | Invicta Subaqua Noma Iii S
I need screws for invicta subaqua noma 3 band model # 6510
Good day I had purchase parts direct from Invicta and found that is easier then looking around for the parts here is the info;
Message Invicta Customer Service . Mon - Fri . 9am - 5pm EST
Email service@invictawatch.com
Call 800-327-7682 . Mon - Fri . 9am - 5pm EST
Fax 954-921-2508 or 954-862-5461
Write Invicta Watch Group
Attn: Customer Service
One Invicta Way (3069 Taft St.)
Hollywood, Florida 33021
U.S.A.
#PS
or you can also check them at their web-site http://invictawatch.com most parts are really low cost with the exeption of the mechanic parts
Apr 17, 2012 | Invicta Subaqua Noma Iii S
What powers my subaqua noma iii gmt limited edition model # foo27
Nov 07, 2010 | Invicta Subaqua Noma Iii S
Zero in second hand
Easier than you think.Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
Aug 29, 2010 | Invicta Subaqua Noma Iii S
Hello, I hope that you can tell me some true info about this watch. It is the Invicta Subaqua Noma III (above). Watch descriptions say that the watch has a unidirectional rotating bezel. Is this true??...
Aug 27, 2010 | Invicta Subaqua Noma Iii Chronograph men...
Need a manual describing how to set the date for an Invicta Reserve Subaqua 6208
Jul 03, 2010 | Invicta Reserve Collection Subaqua Noma...
How do i set the day of the week on my Invicta subaqua noma 6125?
For Invicta chronographs to set the day you need to pull the crown out to position 3 (2nd click after releasing the crown/ furthest crown position/ same position to adjust time). You can only set the day by rotating the crown clockwise. Every 24 hours of clockwise rotation will move the day indicator forward 1 position (Mon>Tue, Tue>Wed, etc). If your watch is set one day ahead of the correct day (Its Tuesday but the watch displays Wednesday for example) you will need to rotate the crown clockwise through the entire remainder of the week in order to get to the correct day, you CANNOT rotate the crown counter-clockwise in order to move the indicator back a day.
May 21, 2010 | Invicta Subaqua Noma Iii Chronograph men...
SUBAQUA NOMA 3 SCREWS LOOSEN AND THE BRACELET OPENS ANYBODY ELSE
What 3 screws? Give me: Make, model, all the numbers on case back. Explain in detail what 's wrong. Where screws are/were located and so on.
Feb 05, 2010 | Invicta Subaqua Noma Iii S
Invicta Subaqua Noma Iii S Logo
1,756 people viewed this question
Top Invicta Watches Experts
Arturs Kalnins
Arturs Kalnins
Norman Worley
Are you an Invicta Watch Expert? Answer questions, earn points and help others
