SOURCE: Hotpoint Aquarius not completing finally spin and pumping out
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
The
filter is inside the machine. Turn off the power and pull out the machine to
get to the rear. Pull out the hose you
see going into the wall pipe, lay at floor level or plastic bag to drain out
remaining water in machine. Remove the panel at the bottom (2 screws) where the
discharge hose comes out. You should see a black concertina type tube coming
from below the drum attached by a jubilee clip. The filter is inside. Loosen
the clip and pull away the tube, take out the filter and clean it. When you
replace it don't forget to put the ball float back in (exactly as you found it)
and check it’s well fixed by running a spin cycle before sealing up. Caution, the exit drain hose shd be fitted at
the exact location where you found it, abt three feet up from ground level.
Pl
rate me nice for the free help, thnks.
Hi Tony Whitehurst, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
