It wont start unless you do something we call bleed. There is a small screw on the side of the injector pump you have to pull those and pump the lift pump/fuel pump untill all the air leaves the pump the close them and start.
p0171 is the code for system too lean bank 1. possible causes intake/exhaust leak--air system maf/vaf sensor-fuel pressure--manifold regulator/ pump--injectors Ho2s Check for leaking rubber hoses. Have a fuel pressure test done and replace the sensor.
The age of this transit should be a self bleeding system. But if not, you will see some metal tubes running into the cylinder head, with nuts at the end. Loosen these and crank the engine over until fuel spurts through. You will only need to do 2 or 3 to get the engine started. I have personally used a damp start spray, in the air inlet to fire up diesel trucks before and not needed to bleed the system at all. Worth a try, just open up the air filter and squirt some into the inlet, crank it over and it should start.
