Question about D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point (DAP-1522/B) Pre-802.11n
How to assign static IP of my access point DAP 1150 to my pc
    Genius:
  • D-Link Master
  • 1,552 Answers
From your computer, get the MAC-address of your network adapter.
Configure the router to always give out the same IP-address for that MAC-address.
Posted on May 11, 2015
6ya staff
SOURCE:
tech curly
Jeffrey Pedimonte
  • 298 Answers
SOURCE: Assigning an IP address to a computer
if you comptuer is runnin on winxp you can try the steps on this link. click here.
Posted on Jul 25, 2008
Anonymous
  • 137 Answers
SOURCE: i have DAP-1160 wireless access point ,i cant
try to connect 192.168.1.1 or 192.168.0.1
Posted on Mar 26, 2010
zhu_1754431
zhu_1754431
  • 108 Answers
SOURCE: Im trying to use the
maybe the wireless configuration of your dap1522 is not configured already.
Posted on Jan 03, 2011
SOURCE: I have DAP-1160 wireless G
I had the same problem with a DLINK DAP-1160, it did not seem to reset and I could not connect, nor PING it. It turned out that the box WAS resetting, and although the default IP address 192.168.0.50 and subnet 255.255.255.0 was being set, my computer was assigning itself up a private IP address and subnet 255.255.0.0. In the manual, it does say that you must be on the same subnet, so I changed my alternate IP address for my ethernet to be static and set the subnet to 255.255.255.0 and everything sprung in to life.
To summarise: make sure the computer you are using to configure the DAP-1160 has its subnet to 255.255.255.0.
Posted on Aug 14, 2012
rameshrai
  • 10 Answers
SOURCE: Router can't detect DAP 1360 when installed about 90 meters away. UTP connectors tested okay.
have you tried turning on and off the router and AP? it would scan again...it looks like you just need to recheck connections and powers...
Posted on Oct 12, 2012
How can I assign IP of my access point Dlink DAP-1150 on my lap top. I want to add adapter network DAP-1150 on my pc
there are 3 ways of setting it up as an Access Point, Wireless Client, Wireless Repeater mode. Would be easier if you explain what you want to use it as?
Choose what you want to use it as, you can set it up plugged into the router or over the wireless , so just plug it into your router and follow the instructions in the manual, you will then be able to unplug it and it will automatically connect to the router over the wifi. manual can be found here ftp://ftp.dlinkla.com/pub/drivers/DAP-1150/DAP-1150_A1_Manual_1.10%28B%29.pdf
Jul 12, 2014 | Samsung R540 Laptop
Cannot access either dlinkap or 192.168.0.50 via web browser in order to set DAP-1360
Connect your computer to the router.
Assuming Windows 7, click the "Start" button.
Into the search-box, type 'CMD' and press ENTER.
Type 'IPCONFIG /ALL'.
Look for the IP-address of the "gateway" (or "DHCP-server").
Type that IP-address into your web-browser.
Nov 24, 2013 | D-Link DAP-1522 Xtreme N Duo Wireless...
I configure a DAP-1150 and can connect via a laptop but my iphone and ipad fail to connect it. However, when I reset the DAP (with no security), the opposite happens! It means that my iphone and ipad can...
That is because your laptop has the saved connection history that you need to delete. Since your acces point does not have security which is not the same as the one that saved from your laptop. Therefore, your laptop won't be able to connect. Go to network and sharing center and from the left side of the page that came up look for change wireless adapter settings and click it. You will be able to see the connections that was saved and the top one would be your connection name. Delete that and close everything. Try connecting to your wireless network again and that should resolve the issue.
Feb 06, 2013 | D-Link DAP-1150 802.11g Wireless Access...
I have DAP-1160 wireless G access point. My pc won't rekognize it. it worked befor reseting, after that the STATUS led does not blink.Not even when it's connected to the pc. What is the problem?...
May 08, 2011 | D-Link AirPlus Xtreme G DWL-2000AP...
I cant get into config my dap1360 by typein in the dlinkap or 192.168.0.50
just make sure that you belong with in the same IP range.
default DAP-1360 IP is 192.168.0.50
username : admin password : <blank>
change your PC IP address to 192.168.0.xxx (e.g. 192.168.0.2)
from there you may choose wizard or manual configuration.
you may change your DAP-1360 IP add according to your network settings in the office and you must change you PC IP address with in the same range.
Mar 24, 2011 | D-Link DAP1360 IEEE 80211n (draft)...
I just got a dap-1360 and i cant set it up when i type dlinkap or 192.168.0.50 in my URL it keeps sayin webpage cannot be found
Internet connection is fine when my PC's connected directly to the modem. The router connects fine. But won't let the wired PC online. Under the "status" bar the "router" tab won't show the correct...
here are times when there is a need to connect a wired computer to an access point in order to set it up. To connect a wired PC to a Linksys access point, follow the steps below. Step 1:
Connect the PC to the Ethernet port located at the back of the access point.
Step 2:
Assign a static IP address on the computer. For instructions, click here.
NOTE: To assign a static IP address using Mac, click here.
The Access Point can be configured in four different modes:
  • Access Point
  • Access Point Client
  • Wireless Repeater
  • Wireless Bridge
The Access Point mode allows wireless clients to connect to the access point and routes traffic between the wireless and wired interface. Use this mode to create a standard wireless Infrastructure network. For instructions, click here.
The Access Point Client mode allows this device to act as a wireless client. You can connect a wired PC to the access point to connect to a wireless router or another access point wirelessly. You can enter the MAC address of the Access Point or use the Site Survey button to select the Access Point you want to connect.
NOTE: The WAP54G will only communicate with another WAP54G when set to the Access Point Client. For instructions, click here.
Sep 05, 2010 | Linksys Wireless-G WRT54G Router
Can't open DAP-1150 configuration utility
The DLink URL WEB configuration uses an IP address not //dlinkap
Try http://192.168.0.1
The default ligin = admin
The default PW = blank ie. nothing
Jan 04, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
Configuring DAP-1150
address to access d-link DAP-1150
http://192.168.0.50
you have to make sure that your ip address is around 192.168.0.xx
Apr 25, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
EOC-3220 connects but no internet access
What are you using for Internet connects? do you have the Access point connected to a Router. or is it connected to the Cable or DSL modem. I will need more information to complete this. If you have a router is is set to give an IP address or do you have a static IP? If it is set to give a Dynamic ip change the access point to recieve ip address from router and same with computer. If your connected directly to the Modem with the access point and you only have one IP address it will be used by the access point and not allow the computer to connect.
for more help please provide your internet (DSL, T1, CABLE) if you have router,  how it provides IP, and how access point is connected to it.
Oct 31, 2007 | EnGenius EOC-3220 (EOC3220)
D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point (DAP-1522/B) Pre-802.11n Logo
241 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
