Question about HTC Wildfire Cell Phone
How to remove the oirplane mode from my dell laptop computer
Laptop boots to a black screen Dell Inspiron 10 min to boot up
Do the following tasks:
Reinstall your video driver
Check for registry issues
Start the computer in safe mode and run System Restore
Also Removing the graphics driver in safe mode might work for you. Just remove it via Device manager.
If black screen still appears then use a system utility software like ReginOut.
Hope it works for you.
Dec 01, 2012 | Dell Inspiron 530s Desktop Computer...
Dell Inspiron 5720
F-8 is the key, Try to "cold start" the computer, meaning remove the power plug from wall outlet or uplug from computer, remove battery, now replace battery and plug computer into wall outlet. Push the on button while "TAPPING" the F-8 key repeatedly Tap, tap, tap, until you hear a beep or it load the black menu with safe mode options. IF THAT DOES NOT WORK: shut down the laptop,remove AC supply, remove battery. Plug the AC power back in,DO NOT INSTALL BATTERY, Start the machine, without battery installed, and tap F-8 repeatedly. If it still fails, PULL THE PLUG OUT OF THE WALL OUTLET WHILE THE COMPUTER IS STILL RUNNING. NOW PLUG THE LAPTOP BACK INTO THE WALL AND START, THAT SHOULD TAKE YOU TO A BLACK PAGE WITH WHITE SCRIPT WITH OPTIONS YOU ARE LOOKING FOR.
Oct 31, 2012 | Dell Computers & Internet
Locked Dell computer operating in Windows 7
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
Oct 06, 2012 | Dell Studio XPS 1645 Laptop
When i turn my computer dell latitude d620 on it comes to the dell screen then the windows xp screen and then it goes black with nothing more than the mouse. what could be the problem?
This sounds like a video issue. Try starting the system into safe mode (after the dell screen, tap F8 to get the startup menu and then select safe mode) When in safe mode, go to the control panel and remove the display adapter driver from the device manager under System > hardware tab. Try booting into normal mode windows- you should be able to get into windows at that point. Download and reinstall the graphics driver from support.dell.com. If the issue reoccurs after you've reinstalled the graphics driver, it means that the video card on your system has gone out. At that point, contact Dell technical support if you are in warranty to get service- if not, try pricing the replacement video card from Ebay or Dell parts service.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Oct 05, 2010 | Dell Latitude D620 Laptop (Latitude-C620)...
Lock my self out keeps asking for password
Restart your computer, press "F8" once you see the Dell logo in the beginning and go in via Safe Mode. Once in safe mode go in via Administrator and remove the password in the user settings.
Mar 20, 2010 | Dell Vostro 1710 Laptop
Black Screen Dell 600 Laptop
The display drivers maybe corrupt.
Boot the machine into safe mode. Right click on My Computer (XP) Computer (Vista) and select manage from the sub menu.
When the window pops up select Device Manager.
A device list will populate. When it has look down the list for Display Adapters. Click on the + icon next to Display Adapters to it expands. Right click on the display adapter and select uninstall.
Restart the computer and let it boot in normal mode.
If it boots in normal mode let it detect the Display and install the drivers for it.
I would be a good idea to update the display drivers via the Dell support website.
If it still won't display in normal mode please post back.
Good luck.
Sep 17, 2009 | Dell Inspiron 6000 Notebook
Computer starts normally then I get a gray page
If you have any windows xp bootable cd use that to fix the problem by running the command chkdsk /r/f or you can try with this just restart the system in safe mode with command prompt and type the command like c:\windows>chkdsk
And
c:\windows>chkdsk /r/f
Sep 16, 2009 | Dell Inspiron 1525 Notebook
Error code on dell laptop
There are two options you can try:
First boot up and hit F8 to put it in Safe Mode. Then go into your Control Panel>Add/Remove programs and uninstall Service Pack 1. Reboot and see if that works. If not try this:
Boot up into Safe Mode again by hitting F8 when it starts up. Click on Start>Programs>Accessories>System>System Restore (It may be a little diff but that is close). Click on System Restore and walk thru the Wizard, this will restore your computer to an earlier date before you installed Service Pack 1. Good Luck.
Dec 22, 2008 | Dell Inspiron 1501 Notebook
HTC Wildfire Cell Phone Logo
61 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
rrackman
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
