WANT TO REPLACE A gli liner have had it for 10 years checking warrenty and cost to replace has a 20 year warrenty
Pool Liners
Wide range of pool liners for varied pool sizes & shapes available online at My Pool Store. Browse our entire range of above ground pool liners & place your order today!
Know more here:
Above Ground Pool Liners
When replacing a liner, for absolute aesthetics, make sure you have a large bed of sand, thoroughly wet it, using a spray nozzle, then trowel smooth, don't be afraid to use the water!
Stretch out the liner while sand is still damp, this keeps it more firm. Once it dries, it is much more soft and will indent.
You can also use a product called Happy Foam. Or Happy Bottom, or Perfect Pool Bottom, Gladon...
Swimming Pool Setup
When liner comes out, take your time to put it all back together, RIGHT. So you will enjoy your pool for many years, both to, be in it, and to look at.
Also... Once you place liner in the pool and open it up and drape over the wall, don't do final stretching and removing wrinkles and creases, until after a few hours of being in the sun.
Good luck
Good luck on your warranty. I'm sure it will be pro-rated. 10 years is a long time for a liner to last. It usually costs 2,000-3,000 for a new liner and installation.
