SETTING THE WAKE TIME You can select two different wake times for music or alarm to turn on automatically. WAKE 1 and 2 controls are located on top of the unit behind the SNOOZE bar.
1. Slide switch to SET position. The display will change to wake time.
2. Use the FAST FORWARD, FORWARD and REVERSE buttons as needed until you reach your desired AM or PM wake time. For music, select an AM or FM station and then turn the radio off. Set wake time and then slide the switch to MUSIC. For Alarm, set wake time and then slide switch to ALARM position. If a wake time is set, an indicator in the display lights and the unit turns on in the chosen mode (alarm or music) at the set time for approximately one hour. To turn off the wake mode, slide the switch to OFF or press the OFF button. NOTE: If both Wake 1 and Wake 2 controls are in the SET position, the time of day is displayed.
GE 7 4825 User Manual
