KitchenAid KCMS185J Microwave Oven Logo
A
Anonymous Posted on Jul 11, 2014
Kitchenaide Superba #4450786A unit turns on but will not heat at any setting. What can I do to fix?
Gerard McHugh
Level 2:
Sergeant:
  • Expert 248 Answers
  • Posted on Jul 12, 2014
Gerard McHugh
Expert
Level 2:
Sergeant:
Answers
248
Questions
Helped
118847
Points
745
Magnetron needs replaced.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Cheaper to buy a new Microwave oven.
1 Related Answer
Anonymous
  • 2382 Answers
  • Posted on Apr 25, 2011
SOURCE: We have a KitchenAid Superba microwave and oven
Hi, it is caused by a blown 20 amp fuse in series with the Primary door switch.
CORRECTION: Most often the first attempt is to change, or adjust, the primary door switch, but components (20 amp fuse, 15 amp fuse and cavity thermostat) in series with the primary door switch are the culprit. Check and replace as necessary the 20 amp fuse, the 15 amp fuse or the cavity thermostat.
My Kitchenaide KEMC378KSS0 Oven Microwave Combo shut down.
Is it possible the cord got knocked loose during the work?
The parts list with exploded views is here.
My site is MicrowaveControl.com so feel free to e-Mail me at [email protected] for details and free advice.
4450786a How many watts?
I don't know offhand, but there should be a plaque somewhere on it with that info.
1helpful
Microwave makes a buzzing sound and will not heat.mo.#4450786a.
The magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Microwave starts on its own and displays PAN
You have a shorting membrane keypad.
I'm contacting you directly.
Kitchenaide microwave not heating - no stange noised, everying else seems to be working just no heat
there are few sensors inside that might go bad but do not try to fix it yourself its got 4000v !!! sorry :( your life worth more then this microwave.
4helpful
2answers
My Kitchenaid Superba kaw38avm726 microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhjjd
Have a kitchenaid superba part no. 4450786A with the probe indicator beeping for a temperature to be set. Prior to beeping started just used microwave to warm food; didn't need or use probe. What is...
Put the probe in the oven and beeping stopped. Left it in overnight and next morning took the probe out and there was no beeping. Have not heard beeping all day. Don't know why this worked but it did.
LaMason
Microwave serial # xr2004675 superba heating
If the door seals tight & properly and the fine screen / mesh in between the door glass panels is not damaged, there should be no leakage.
But the risk remains that moisture and food particles will get into cracks and crevices and lead to arcing or rust, both of which can eventually damage the mesh.
What is the small curved piece that's falling out? Can you post a photo of it?
We're happy to help and we appreciate your thoughtful rating of our answer.
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
