SOURCE: Samsung CLX-3160FN prints and copies fine but can't scan
This may be obvious, but there's a "scanner lock" on this machine. It ships locked, and you need to unlock it when you receive it. Look up under where the paper comes out when you print, and on the left there's a little green switch. Make sure it's pulled towards you (you can see it also through the glass on the scanner bed).
SOURCE: samsung clx 3175 toner chip overide/reset?
we use chip and fuse for samsung cartage reset when it give us cartage empty message. before geetting thish we gets tonner is low .if recently we filled samsung dust/powder/tonner in cartage we no need reseter. in my practics while i need to put fuse (reseter) i put iton cartage after resetin suddenly i putout it from cartage and use old fuse. in this way we can use or not green chips? actuly it is difficult.
SOURCE: 4 Samsung CLX-3175 WITH THE SAME PROBLEM IN ONE WEEK
The exit sensor is bad, there's a bulletin at Samsung. You need to remove the fuser and the top cover, the sensor is on the top left of machine The sensor is #0604-001393, about $1.00 from Samsung
Testimonial: "Great no more words just great"
SOURCE: My clx-3175 wont print black and white when color
All of the manufacturers do the same thing to get people to buy their toners, if any toner is empty you don't get to print even black. Sometimes empty toner can scratch a drum so that's the excuse they use for making them that way.
SOURCE: i am getting deve home sensor error on my samsung
Dev. Home error can be fixed by stretching out a solenoid spring on the power cord
side of the printer. The solenoid acts as a clutch to stop the spinning
developer actuator at the right spot.
The problem is that the spring gets weak over time / the cogs round out
over time and the solenoid finger is overcome by the spinning cogs, and
resulting in selecting the wrong developer.
Open up the right side (power cord side) of the printer (take off top
cover, then take off side cover). Then, find a solenoid (little metal
square) that touches the white plastic vertical spur gear. Take the
spring off the solenoid. Now, put the spring back on - only this time
you will attach one anchor point to the middle of the spring as to
pre-stretch the spring for more tension.
More pictures of the solenoid on Facebook:
http://www.facebook.com/#!/photo.php?pid=55779771&id=2257206&fbid=10100154259704133
