Question about Frigidaire Affinity ATF7000E Front Load Washer
Why does washer say no water during final spin
SOURCE:
  • 10 Answers
SOURCE: Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Posted on Dec 15, 2007
  • 210 Answers
SOURCE: E21 error while on final spin
E21 is telling you that it has not drained the water out. You may have something stuck in your drain pump.
Sgt 48
Posted on Jun 03, 2008
SOURCE: Washer will not Spin during SPIN CYCLES
IT IS THE DOOR LOCK ASSEMBLY, COST AROUND $50.00 WHICH IS FAR BETTER THAN $300.00, WHAT A SERVICE REPAIR PERSON WILL CHARGE YOU. YEA IT'S THE CRAZIEST THING IMAGINABLE, THE DOOR LOCK ASSEMBLY BEING THE CAUSE FOR IT TO NOT SPIN ALL THE WATER OUT. I FIXED MINE MYSELF, HAD TO TAKE IT ALL APART VERY CAREFULLY, BUT I SAVED MYSELF $250.00. YOU CAN GET THE PART ONLINE OR GO TO NEAREST APPLIANCE PARTS STORE IN YOUR CITY. ASK FOR DOOR LOCK ASSEMBLY. THEY WILL KNOW EXACTLY WHAT YOU'RE TALKING ABOUT BECAUSE IT IS A VERY COMMON, I REPEAT VERY COMMON PROBLEM WITH THIS BRAND OF WASHING MACHINE.
Posted on Aug 12, 2008
SOURCE: Final Spin Cycle Not Working
I unclogged the pump, it was really easy, and it fixed my problem (I have no mechanical know how)! let me explain how I did it!  I have the Frigidaire Front loader for two years, it was acting funny, wouldn't spin, wouldn't drain. My solution was quick and simple, per a solution already mentioned on this site.  In short, The rubber drain was clogged.  There were two cotton breast pads, that must have been in there for months.  Recently my washing machine would not drain, and therefore wouldn't even think about spinning fast.  To unclog, first take off the front bottom panel.  (There are two tight screws on the front bottom, next to the floor, I had to use a powerdrill to remove them, and tilt the machine against the wall to get to them).  Next, there was a black rubber accordian on the front right, where the water drains.  (remeber to unplug your washing machine, to avoid any shock or such!)  I simply unscrewed the big metal ring, (I think it's called a gasket). After unscrewing the metal ring, I could easily pull the rubber accordian down 2 inches, stick my hand in it, and pull out debris.  I pulled out debris for about 5 minutes, and was so excited because I knew my washer would work great again.  I simply put the rubber accordian part back on the lip, screwed the ring piece pretty tight. I used a towel to absorb a small amount of water, that got inside the washing machine.  Now, it is spinning a million miles per hour again.  I will put the rectangular bottom front panel back on in a few days, I just want to double check, there is no leak, which there is no reason to suspect, as removing and putting the metal ring back on was easy!.
Posted on Dec 24, 2008
  • 636 Answers
SOURCE: my washer washes but dosn't drain or final spin
sounds like a sock or something may have become logded in the drain line.
Posted on Jul 26, 2009
Is water supposed to enter the tub during the first half of the final spin cycle (not rinse cycle)?
no spin cycle don't have water it could be the pump is not getting the water out fast enough, could be clogged or the rear drain pipe is blocked or bent. failing them to problems it could be the valve its self.
Aug 04, 2017 | GE WBSE3120B Top Load Washer
Washer is not completing the spin/drain cycle. Stops spinning and draining.
does it drain out all the water? after it stops or is there still water sitting in the tub?
Mar 22, 2011 | Kenmore Elite 45986 Front Load Washer
Water runs during final spin cycle
You have a blockage in the drain pump. Remove the front panel to access the drain pump.
Bail the water from the tub.
Remove the hoses on the pump and clean out the lint or garment from the pump.
Mar 26, 2009 | Frigidaire Washing Machines
Cold water pours in during final spin
No - the timer is the likely suspect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
There is something clogging your pump, dismantle it to clear it. Plug off the wall socket mains first.
Jan 15, 2009 | GE WDSR2080D Top Load Washer
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. (consult your manual to know where/how filter is cleaned). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 29, 2007 | Washing Machines
Frigidaire Affinity ATF7000E Front Load Washer Logo
70 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
