check your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. no fill If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
This sounds like the water mixer valve needs to be replaced. Its the part the fill hoses screw onto at the back of the washer Unscrew the fill hoses at the back and run water in washer to verify the water is there.
If this was helpful please rate me. IMUFO2 Leo Ponder Appliance-Tyler,Texas [email protected]
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Firstly, check to see that your water temperature is selected properly. Next, check to confirm water supply to the washer is adequate, both HOT and COLD. If confirmed, try replacing the fill valve.
