Vizio GV42L 42 in. LCD Television Logo
A
Anonymous Posted on Jul 10, 2014
Whats an antenna - Vizio GV42L 42 in. LCD Television
I need an antenna for RCA RP7664A portable radio. What kind should I look for?
There are 4 things you need to look at for the replacement, the two most important details are how the antenna is attached inside the radio, and the second is the outside diameter of the antenna. The other two details are the collapsed length and extended length. You will need to open the radio to see what attachment method is used, usually a small screw through a hole through the base at the end of the antenna. There will also be a wire attached with the screw (usually), that connects to antenna to the radio circuits. Carefully remove the broken antenna from the radio, then you can note the attachment method, and measure the outside diameter, and the collapsed length.
Trying to check which fuse is for the power antenna
What fuse disables the Automatic Antennae? - Toyota ...
www.toyota-4runner.org/.../70614-what-fuse-disables-automatic-antenna...
Aug 25, 2010 - Is there a fuse that disables the automatic antenna? ... For the price of 1 toyota power mast you get a whole assembly and it won't break again.
power antenna fuse location? - Corvette Forum
What antenna works on Toshiba 20VL43U? I purchased Mediasonic Homeworx HW110AN Super Thin Indoor HDTV Antenna - 25 Miles Range.
I recently went through a whole song & dance about HDTV antennas for my RV. I bought two different directional high-gain antennas, only to find that they wouldn't even receive signals at my home! When I'd reorient the antenna and initiate another channel search, I would sometimes get ONE or TWO channels... then I'd lose them when I'd try to reorient the antenna.
What I figured out is that DIRECTIONAL HDTV ANTENNAS ARE, ESSENTIALLY, WORTHLESS. There is really no way of knowing precisely which direction the broadcast towers are and, even if you knew, they will not all usually be clustered in one small area... they may be scattered here & there around your area.
What I eventually did is bought an OMNIDIRECTIONAL HIGH GAIN ANTENNA, which was no more expensive than the DIRECTIONAL antennas I tried. Did a channel search, and got almost all of the channels in my area!
Any omnidirectional HDTV antenna will work with your television, but I'd recommend buying the one with the highest GAIN (expressed in "dB" or "dBi" with the highest number being best). Try to find a POWERED antenna with an internal SIGNAL AMPLIFIER.
Also, if you live far away from broadcast towers as I do, you may wish to consider adding an additional SIGNAL AMPLIFIER as well.
1helpful
My RC control only works within four feet of my boat. What is wrong ?
Check the Transmitter Antenna and battery. low battery means short range and the antenna could be broken. Have it checked by a radio modeller shop, but first replace new batteries and inspect the antenna. I don't know what brand it is, so I don't know what antenna you have, an extendable antenna or a short stub.
Mar 08, 2015 • RC Toys
1helpful
I just purchased an indoor antenna for to view local stations. Can i use an indoor antenna for my olevia 232-t11 lcd-hdtv? If I can, what steps do I need to follow?
Yes you can use an indoor antenna. Just make sure it is an HD antenna to get the digital channels clearly. You will have to do a scan to pick up local channels. In the TV menu, it will ask you if you want to scan for "cable" channels or "antenna" channels. You want to choose antenna.
1helpful
2answers
Can I use an antenna on my sharp tv catv? If so, what kind works for this tv
Hook up your rabbit ears and auto tune the TV and see what happens.
What kind of indoor/outdoor antenna I need to purchase for this TV? What specification do I need to look for?
Hello
An outdoor antenna is more better than indoor antenna. If we fix an indoor antenna, especially in rooms in a flat type structure buildings, due to its iron network structure reinforced inside its concrete will oppose a considerable obstruction to tv signals to get through. Moreover, if any paerson walk through these telescopic type antenna, picure will get shiver of it will be distrurbed.
So buy an outdoor antenna, and hoist it at suitable place, where there are no obstructions comes between the signal path of the transmitter and the antenna. Get an antenna, whcich has as many as cross elemets, if it is a yagi type. As number of elements increses, the sensitivity and seletivity of the antenna will also increase, resulting in good and detailed picture clarity. OK
What is smart antenna for the convertor box?
Smart antenna is a device that connects to the antenna, and send information on the channel received, adjusting itself for the best reception of that channel.
See below :
What is smart antenna? - a definition from Whatis.com
Smart antenna - Wikipedia, the free encyclopedia
Smart antennas
Power antenna
there is a little white colored track inside antenna that the antenna slides up and down on if this has broken you would have replace the whole unit this would be the cause of the antenna not going up
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
