Menu appears on screen but doe not respond to touch. Mechanical buttons respond
Common problem. There is a flexible cable that goes from inside the body to the flip out LCD screen. More than likely, this cable needs to be replaced. Time for Professional service. We can help!
Contact Us at AVRepair com
SOURCE: LCD screen will not respond to touch
First of all examine the LCD connecting flexible strip. If faulty or broken, let me know. Sivaram.V [email protected]
SOURCE: Touch Screen not responding to Touch
the flexwire cable is have an openline and that line is connected to the touch screen panel...it have to repaired or replace that flexwire to the service center....in our shop we modified that wire and became more durable than the original wire......:-)
SOURCE: Touchscreen buttons not working
the flexwire is the problem of your camera, the touch screen connection is already cut..go to a service center for replacing or repairing the flexwire...is not easy for repairing that if you are not a technician that wiring is like a strand of hair that why is difficult to fix but in our shop we modified that and become more durable than the original...
SOURCE: touch panel menu unaccessible
I've got the same problem ... LCD touch screen didn't work, then the screen went dark -- it's the ribbon cable. If you invert the screen flush against the camcorder, you should still be able to access the touch-screen menus (at least mine still work that way) -- to film, you have to use the eyepiece. But, ultimately, the ribbon connection - which is noted for failure -- has to be replaced.
Use the camera Remote Control to control the camera finctions instead of touch screen.
