SOURCE: Will Not go to voice mail
Jennifer209, if you press FEATURE + the button VM is pre-programmed on what does it display? It should show the extension number pilot to VM. If you call it directly, what happens? If you get no answer calling it directly, your VM may be down.
Kaait, is it getting into the VM that's the problem, or doing things inside the mailbox that is the problem?
SOURCE: NEC Dterm 80 calls won't go to voice mail
for us i just found this out.
1.Fwd B/NA
2.1 - 1:set-0:cancel
4.200
5.speaker
after 4 rings it goes to voicemail
this works for us.
i hope it works for others too.
turn this feature off
1.hit fwd b/na
2.0:cancel
3.exit
4.exit
should see the normal display then.
SOURCE: NEC DTU-16 D phone voice mail locked up
Cleared voicmail on all other extensions and waited, it eventually (3hrs later) cleared itself
