Idicator flashing? I get a code P2770 I swaped out the engine started it up and the engine light and gear indicator started flashing I get a trouble code P2770 Also in limp mode
The shift solenoid valve DSL is turned "ON" and "OFF" by signals from the Engine Control Module (ECM) in order to control the hydraulic pressure operation, the lock-up relay valve, which then the controls operation of the lock-up clutch.
Torque converter lock-up is controlled by the ECM based on engine rpm, engine load, engine temperature, vehicle speed, transmission temperature, and shift range selection. The ECM determines the lock-up status of the torque converter by comparing the engine rpm (NE) to the input turbine rpm (NT). The ECM calculates the actual transmission gear by comparing input turbine rpm (NT) to counter gear rpm (NC). When conditions are appropriate, the ECM requests "lock-up" by applying control voltage to shift solenoid DSL. When the DSL is opened, solenoid DSL applies pressure to the lock-up relay valve and locks the torque converter clutch. If the ECM detects an open or short in the DSL solenoid circuit, the ECM interprets this as a fault in the DSL solenoid or circuit. The ECM will turn on the MIL and store the DTC.
