SOURCE: I bought an older pool pump, 108R. The hose goes
i bought the universal twin pack replacement
A/C Filter Cartridges Fits all pump models using 8 in by 4.25 filters replaces A or C filter cartridges
and it works in mine on the bottom there is a white
round thing that holds it there and the top is a black ring with a big round thing then the top with the hose on it screws on
any way bought at walmart
SOURCE: I have a 24' round
The purchase of the salt water system will only helped you with not needing to pour chlorine in or float tablets.
You will still need to use chemecals like.
Use a good stabilizer to hold the chlorine level longer
Use a non foaming algecide once a week
And also use a water clarifying product once a week
Also cloudy water is because of not enough sanitizer mixed with a crappy pump from index
So now for your size of your pool you have a 13000gl pool you will need a 4500gl ph pump
A pool needs to be turned over at LEAST 3 times a day so for me it takes at least 8 hours of filtering alone this does not include making chlorine.
Bottom line your pool has about 13000 gallons, you would be looking for an 8 hour turn over rate, A 1.0 hp pump, rule of thumb, will move 35 gallons per minute, should be moving 2000 gallons per hour and your turn over rate is about 4 1/2 hours. This will avoid to run your system 24/7 between generating and straight filtering
