SOURCE: dvd/vcr combo,vcr is fine ,but dvd no picture,or sound,disc reads.
Hi There is an I/P button on your player's remote control. Power your player on then press the I/P button on your remote control.
SOURCE: color to black and white and back again
if you are using S-video cables for your video, try replacing the cable. svideo has 2 lines in it, one for color (chroma) and another for brightness (or black and white-ness (lumina) if one of those little pins is broke, or missing, or the cable is bad, this may be the case.
SOURCE: My Hyundai DVD player plays
On the DVD Player, there maybe somewhere where you can change the output to the television (Scart) from RGB to Component or Composite-mode.
RGB causes some displays which cannot handle the RGB signals to black and white.
I hope this fixes your problem.
Finally, some TVs designed for PAL cannot handle NTSC discs played through them. It causes the display to also go Black and White. If this is the case there is nothing you can do except change the display/TV.
Don forget to rate.
Try to check the TV system it might be set to PAL or NTSC...
SOURCE: black rectangle at bottom of screen when playing dvds on sony dvd player
Had the same problem but was able to fix it by simply doing the following:
"this is closed captions turned on your TV. get your original TV remote and look for a button that says "Captions" or "CC", and keep pressing it until the TV says "Off". if it doen't have one of those buttons, you will need to get into the menu of the TV and turn off closed captions there. It is probably set on "Text1 or Text 2" right now, and it needs to be set on "Off"
