There is water pooling in the bottom of the fridge and seems to be coming from the filter. I replaced the filter and it continued to leak. Seems to be coming from the housing or something before the water reaches the filter. I cant seem to be able to disassemble the housing for the filter to look further. Where could this water be coming from? How do I take apart the filter housing?
SOURCE: Samsung RSH1DTMH fridge freezer water filter replacement
The water pipe connection to the filter is a one way fitting which means that the more one pulls to free the pipe, the more the filter connection grips it. There is a circlip on each end of the filter - push the circlip firmly in towards the filter while pulling the pipe free, it should come free easily. Needs 3 hands, two to depress the circlip and one to pull the pipe free. Preferably put a container under the filter (there can be a bit of spillage) while you're replacing it and remember to test the connections once you've fitted the new filter before pushing the fridge back into place.
Samsung's instructions should be clearer.
SOURCE: RS253BAWW Samsung Side fridge water leak
I would not be too alarmed about this. Most refrigeration systems will
drip water off of the condenser coils while in use. This can most often
be seen by cars that appear to "leak" only when the a/c is on. All that
this "leakage"is is condensation. This is the same reason that window air conditioners need to have a slight downward tilt to the outside. This is also why they unfortunately, often freeze up.
If you're only noticing leakage while the refrigerator is running then I would bet even money
that this is what's happening especially if the refrigerator is still
staying cold. Most normally this condensation is caught in a drip pan
which lets the water evaporate. However, during periods of extended
use, especially with periods of high humidity i.e. the summer,
sometimes the condensation is higher than what the drip pan can hold
and you get leakage over the sides.
Unfortunately while this
is a relatively minor problem about the only way you are going to
eliminate this is to install a dehumidifier in your home, or simply
tolerate it for a month or so during the summer. I would bet dollars to
peso's that after mid august this won't be a problem.
One
thing to note however, is that if you start to see that it is running
constantly, or if you notice that it's not keeping cool, then it may be
time to call in a service person. But for your particular problem I
don't think that will be necessary.
Actually a pretty common concern... second time in two hours I've seen it. :D
SOURCE: water is leaking on the inside bottom draw of the
Clean the drain tube and drain pan under fridge.It may be clogged.
Hope this helps.
SOURCE: Small amount of water leaks from the front of my Samsung R2630SH.
I found out that there is a plastic panel that cools three draws inside the refrigerator. Behind the plastic panel there is an evaporator (coolant childer) that catches the condensation of repeatedly opening and closing the refrigerator door that turns into thick ice. Because of condensation, ice buildup in such a way that the ice pushes the middle draw out causing the door to open. In turn depending on how long the door stays open, melts the ice and the water leaks under the bottom draw out on either side of the front refrigerator door. Also, there is a drain plug that is also iced closed. To solve that problems, the unplug the refrig, put towel under the refrig, removed the panel (unplugging the wires and removing screws) and took a hair blow dryer to melt the ice. Oh, by the way, I used to blow dryer to melt the ice from the panel before I could remove the panel. That job took all day. I removed all the ice and reassembled the panel and replace the drawers. To my amazing, no more leaks and the water dispenser worked for two days and quit. I believed the water tank (plastic container in front of the panel has frooze again. By the way the ice maker did not work after removing the ice.
SOURCE: water gathering at bottom of fridge.
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
