Hello! We have several Purpose for Pets models. I have included the link to the Purpose For Pets Bagless Upright Vacuum model M140000 instruction manual. If this is not the model you have please reach back out to us and include the model number. Hope this helps!
http://bit.ly/1pB8DM1
SOURCE: HEPA Filter
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618630&thid=730623
HEPA Filter
Posted by jenski66 on Jul 02, 2008
My vacuum came with a sponge over the filter and the directions said I could wash the filter. Do the directions mean to wash the black sponge or the actual filter? Is the sponge part of the filter or is it trash?
Filter F27
Dirt Devil Purpose Cleaner for Pets
Upright Bagless Vacuum
Model #1LY2108-000
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Typically the top filter of which is the sponge is washable but the HEPA filter is not, it can be brushed off and vacuum off with another vacuum, but the best filtration is to replace the HEPA filter and to wash the sponge filter, if the sponge filter get to bad then replace the sponge filter as well. Or, you can check with your local vacuum cleaner dealer in your area or to contact the manufacturer’s website and or phone #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: Dirt Devil Purpose for Pets
I had this same problem. All of a sudden it shuts off while vacuuming and then i'd have to wait a while before it would turn back on. Finally it stopped working period. Before going out to buy a new vacuum, I decided to take the thing apart and clean it up really good. That included running a clothes hanger through the tubes to get all the stuck hair out, removing the roller and getting all the hair untangled from it, and rinsing out the air filters (both the sponge and the plastic piece with the paper like filter) with hot water. Then you let the filters dry for a day or two. The plastic/paper filter takes longer to dry so I used a hair dryer. The vacuum itself is not hard to take apart. I think there are only 11 total screws you need to take out. After the filters dried I put them back in the newly cleaned vacuum and it worked like new. I think the main problem was the condition of the filters. They can get pretty filthy over time, which will limit the air flow to the motor. With less air the motor is more likely to overheat and shut off. So keep your filters clean and you shouldn't have any proplems.
SOURCE: dirt devil vacuum cleaner purpose
returned item to store of purchase and received store credit.
SOURCE: dirt devil purpose for pets vacuum quit working
The motor overheats from the filter being clogged underneath the canister or the canister or both are clogged-without the air flow the motor overheats and shuts off as a precautionary measure.By letting the motor cool off it will start again but will turn off shortly if the filters are not properly cleaned.Hope this helps everyone.
Rob
