SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
SOURCE: i need to find a
HI there u can find the instruction manual on the tagheuer site.
Heres the link for your reference.
http://www.tagheuer.com/the-collection/monaco/monaco-sixty-nine/index.lbl?w=CW9110.FC6177
SOURCE: hi there i have bought a second hand tag heuer
Great watch! Operation should be pretty straight forward. The top button starts the chrono and stops it. The bottom button resets it. To calibrate the sweep arm into the right position pull the crown out to the first or second set position and press the start button until the sweep arm is in the start position you desire. This is typically 12:00 or 0.
If your chrono is not working then have the battery checked. If the battery has been recently replaced then make sure the watch doesn't need to be cleared.
I recommend you take this to a watch maker/technician who will be familiar with the service requirements of this model including resealing and pressure testing the watch to be sure it is sealed to its marked water resistance specifications.
Thanks!
SOURCE: looking for an owners manual for my Tag Heuer
Go to the TAG web site ( insert "www.tagheuer.com/the-collection/" into your search engine).
Select "Carrera"
Select "men" or "women" as appropriate.
Select the model of the Carrera you have.
On the right of the screen you will see a list of options, select "user manual"
Adjust the magnification to make the text readable.
SOURCE: User Manual for a Tag Heuer Model WG5111-PO? I
On links below are the only manuals that tag heuer have.
http://ww2.tagheuer.com/_documents/manuals/ei2246_en.pdf
http://ww2.tagheuer.com/_documents/manuals/EI2241_en.pdf
http://ww2.tagheuer.com/_documents/manuals/EI2250_en.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
