SOURCE: No Drainage Stoppage?
The drain hose has to be higher than the full water tub level or it will keep draining out make sure your hose is high enough
SOURCE: Washer won't spin or drain
The problem is most likely the lid switch assembly. The lid switch is a safety feature that will **t allow the washer to go into the spin cycle unless the lid is shut (so ** wandering children get caught inside).
If the switch is working, you should hear a click when the door closes and makes contact with it. If the lid switch is defective/broken, the washing machine usually won't drain or spin. If it's bad, you will need to replace it. It should be mounted inside of the cabinet, just under the door of the washer (on most models). Please let me k**w if this corrects your problem.
SOURCE: Haier HLP21E 6.6-Lb How do I remove lint filter?
You grab the plastic top and bottom of the filter and kind of pinch it so it pops out. It's held in by small pegs on both ends.
SOURCE: When tub filling, it drains out at the same time.
The outlet of the drain hose must be higher than the water level inside the tub--normally the pump inside removes the water when needed. Get a plumber to install a proper height drain pipe for you.
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
