HI,
Please reinstalled Printer driver or restart computer or printer then you new driver installed it. Or installation before scan virus and removed it. Or proper check it all connecting cables.
Read more Help.. HP DESIGNJET 9000S SYSTEM ERROR 1120 and HP Printer Support
Thanks,
SOURCE: cant not star my printer i get this masage Hp
that means that there is an error with the actual printer. The best thing to do is to take it to where you have purchased the device and they can then see what is causing the problem physically and if its still under warranty they can then swap it out for you
SOURCE: we have a hp 9000s
1290: End of Life of Part Reached
Problem Description: The end of life of the Prime Assembly has been reached since it has been working for more than 58 hours. Corrective Action: Replace the Prime Assembly. You will need to replace the Prime Assembly PN Q6670-60062
Try the following:
SOURCE: error 1180 en hp 9000s que es?
Amperage in park station engine is too high. You should lubricate all gears around it.
