Hello! Below are general trouble shooting steps for your Dirt Devil vacuum to restore suction.
1. Check the hoses for clogs.
2. Clean and replace your filters if needed.
3. Check that your brushes are still spinning, if not, replace your belt with the recommended belt for your vacuum.
Hope this helps!
SOURCE: dirt devil swivel glide - no suction
check the filter gauze on the unsud of vack where bag is if this is blocke you will not have vacuum as there will not be ventilation thro this filter should be able to feel blow of air from this vent when vacuuming up hope this helps good luck from uk !
SOURCE: No suction, belt is good and turing brush
take off the bottom cover, and see if something is clogged. trace it all the way to the impeller
SOURCE: dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
SOURCE: i have a dirt devil featherlite deluixe carpet
remove the "remove to attach hose" plate.. that is where the hose connects, plug the solution line into the little nipple below the tank on the right side. then you turn it on. Suction will be redirected to the hose, and the trigger on the hose sprays the solution.
SOURCE: I have a dirt devil carpet steam cleaner. model
I took the advice on the chat site and checked the tightness of the gaskets on the bottom. They were not secure. Once I fixed that all was well.
